Need help with unilight controller.
2 Attachment(s)
I bought the 2 channel Unilight controller from dreamworks with four LED's. Can't get it to power up. Hopefully missing something obvious? I plug power in, plug it into rx... assign a three position switch... nothing. Did the 10 second system reset while powering up the rx... nothing. Do I do this without the power to it? Shouldn't something fire on the board (small LED indicators) when I supply power or RX signal? I increased ATV's to 110 to see if it was missing... nothing.
love some help! |
It's hard to diagnose without seeing exactly what you're doing so can only ask the obvious questions.
Have you plugged a servo into the receiver instead of the controller to check that the channel is working correctly? I assume you have power to both the RX and the controller? And I assume that both are fully charged? |
yes to all.... ;-).
| All times are GMT -8. The time now is 12:02 AM. |
