RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Yellow F-18 Twin pointers and control throws. (https://www.rcuniverse.com/forum/rc-jets-120/11651330-yellow-f-18-twin-pointers-control-throws.html)
jetsflyin 07-10-2018 02:39 PM
Got a great deal a few years ago and finally got around to finish it with the help of a friend. Has a few bumps and bruises but overall beautiful plane. Any last min pointers and throw setting will be greatly appreciated.
https://cimg5.ibsrv.net/gimg/www.rcu...8e33166ccb.jpg
https://cimg6.ibsrv.net/gimg/www.rcu...bc6576a53a.jpg
https://cimg7.ibsrv.net/gimg/www.rcu...4b3d0d2611.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...59a0023c3c.jpg
https://cimg9.ibsrv.net/gimg/www.rcu...c98f1c410b.jpg
https://cimg0.ibsrv.net/gimg/www.rcu...425c597371.jpg
meps 07-10-2018 03:51 PM
Mine flies perfectly at factory recommended settings. CG is set to factory as well.
Steve
jetsflyin 07-10-2018 04:59 PM
I don't have a manual, what are the factory recommendations?
Thank you in advance
meps 07-10-2018 05:21 PM
I'll dig out my manual tomorrow afternoon and let you know.
Steve
jetsflyin 07-10-2018 05:47 PM
Great!!! Thank you so much.
meps 07-11-2018 01:39 PM
As per the manual :
CG is located directly on the front main spar.
Elevator deflection: Hi rate: 1 1/2"
Lo rate: 3/4"
Aileron deflection: Hi rate: 7/8"
Lo rate: 1/2"
Rudder deflection: 1" each way
Steve
kevinthoele 07-11-2018 02:27 PM
Jetflin
I have had a bunch of Yellow F18 twins. The above throws are good. Balance as above with gear retracted and slightly nose down not perfect level. No fuel on board. They fly better a little nose heavy from spar
jetsflyin 07-12-2018 06:48 PM
Thanks for the input guys.
pedroglow 11-13-2023 03:07 AM
Hello, I have purchased a yellow F-18, I think it is the twin, although it comes with a bench prepared for a single engine and a Y-shaped exhaust pipe (2800mm long)
I have been looking for the assembly manual for this model for some time without any results. Does anyone have this manual or know where to get it?
Thank you very much in advance
ww2birds 11-16-2023 09:54 AM
The only other thing I'd add after watching dozens of maiden flight videos of F-18s (Yellow and others) and having flown my own .. is to make absolutely sure that the wing's angle of attack is positive on the takeoff roll. Not just standing still with power off but with the engine powered up for the takeoff roll. You can see the nose dip when power comes on. On my Yellow twin this required a much stiffer nose gear spring than stock (the Yellow nose gear has a clever two-spring arrangement).
The reason for this is simple .. since the F-18 is a Navy aircraft, the main gear are well behind the CG to prevent the tail striking the deck while parked in rough seas. Thus to rotate the aircraft from takeoff roll to flight, a LOT of downforce is required in the stab. Just push it down while the plane is sitting on the ground. You will be amazed how hard you have to push to get the nose up. It's dramatic! Anyway, if the nosegear springs are compressed and the wing AoA is negative you have to get going REALLY fast, with full up elevator to unstick the aircraft from the ground, at which point it rotates instantly and goes almost vertical. A good (but unintentional!) test of pilot reflexes to save the aircraft ensues.
This "really fast then jumping almost to vertical" pattern is a common feature of F-18 maidens. It's easy to avoid .. just make SURE the wing remains at positive AoA through the takeoff roll .. hold half up elevator on the roll and the plane will take off on its own.
All the best for a great maiden .. it's a really nice machine!
Dave
pedroglow 11-16-2023 11:11 PM
Thank you very much Dave for these tips, which will undoubtedly be very useful and these interesting things are not usually told by the manufacturer in the manual. (which I am waiting for a kind friend of the RCU forum, Ladi River, to send it to me) .
The same thing that you tell me happens to another of my planes, the Airword F-5.
Again, thank you very much for the advice!
