Thin safety wire
Where can I get it? and what's the gauge I should be looking for to wire the Ts on the airlines.
Tks. |
.020 is what you want. I seem to have a never ending supply of it around me being an aircraft mechanic lol so not sure where to buy. I would think aircraft spruce would have it. |
Here's what I use.
http://www.aircraftspruce.com/catalo...safetywire.php Safety wire pliers are not a necessity, but they do make the job easier. |
I highly recommend safety wire pliers. I must also say that DO NOT GET THE HARBOR FREIGHT crap ones. I was working on a friends plane and he has them and I wanted to throw them out the window. I ended up doing the job by hand. You don't need to get the ones I use from snap-on but you cant get crap ones either. Middle of the road ones will work fine.
Re wire pliers.
I have built loads of jets for customers in the past and have always found safety pliers to be too bulky for use on our kits, often access is tight and the need for a more agile tool in needed. I made a safety wire tool which I have used for 10 years without fault and its cost me a few cents. Find a steel solid rod around 4mm in diameter, file or Dremmel one end to a flat, about 20mm in length so it resembles a flat head screwdriver when looking on end - about 1mm thick should be fine. Then drill one hole near the tip (round off the tip edges) about 1.5 - 2mm in diameter (enough to pass two pieces of safety wire through with some spare room) - thats it. To secure pass the safety wire round your connection, forming the loops round a pencil etc before can help, then the two tail ends need to be passed through the hole in the tool in opposite directions, one in from the left and one in from the right, pass the tails up along the rod shaft and hold with your fingers as you rotate the tool, once the wire twists a few times the wire self locks in the tool. Twist until you have the desired number of twists and use a small wire snipper to free the tool. Dress the ends around the pipe as required and remove the cut ends from the tool and you are ready for the next. The tool will get into the tightest spaces and will never break as there are no complex moving parts. Hope that has explained it OK, may be able to find a picture of my tool if needed. marcs |
You can get galvanized steel wire at Home Depot, Lowes, or at most hardware stores. It doesn't have to be stainless or say "aircraft" on it.
https://www.lowes.com/pd/Hillman-20-Gauge-175-ft-Galvanized-Picture-Hanging-Wire/50029238 Also I use a large hemostat to reach into tight spaces and twist it. |
Originally Posted by marc s
(Post 12499004)
Re wire pliers.
(Post 12499004)
Re wire pliers.
I have built loads of jets for customers in the past and have always found safety pliers to be too bulky for use on our kits, often access is tight and the need for a more agile tool in needed. I made a safety wire tool which I have used for 10 years without fault and its cost me a few cents. Find a steel solid rod around 4mm in diameter, file or Dremmel one end to a flat, about 20mm in length so it resembles a flat head screwdriver when looking on end - about 1mm thick should be fine. Then drill one hole near the tip (round off the tip edges) about 1.5 - 2mm in diameter (enough to pass two pieces of safety wire through with some spare room) - thats it. marcs I have several donor screwdrivers in mind. Sparky |
https://cimg1.ibsrv.net/gimg/www.rcu...238ecd4b9.jpeg https://cimg3.ibsrv.net/gimg/www.rcu...074567365.jpeg Pic of the pliers I use. Have a set at home and work. they are reversible and have rubber on the cutters to catch the pigtail when you cut it so it does not fall into the plane. |
BikeMaster Safety Wire Pliers... https://www.amazon.com/dp/B002W2A0MW...p_mob_ap_share Malin Safety Wire / Lock Wire &... https://www.amazon.com/dp/B01BDVX34O...p_mob_ap_share i recently ordered both from amazon. These pliers are way better than the Harbor Freight pliers, ask me how I know.. |
A hole in an old small flat blade screw driver works great too :)https://cimg3.ibsrv.net/gimg/www.rcu...af3f2a1de.jpeg |
Originally Posted by gunradd
(Post 12499021)
Marc I hear you about tight spaces but 90% of the safety wire work can be done before you install it in the plane with proper planning. I guess I'm also used to tight spaces on the full scale aircraft so I don't really have any problems doing it in the plane.
Originally Posted by camss69
(Post 12499031)
Twist the wires around each other once by hand, grab the wires at the twist with a pair of long-nosed pliers (which you have around anyway), pull, and twist...
Easy peezie. Bob |
(Post 12498973)
I think he wants the smaller size wire for air lines, not the regular stuff we use for fuel fittings. |
Originally Posted by causeitflies
(Post 12499116)
(Post 12499030)
(Post 12498999)
Army crew chiefs do it all by hand, not allowed to use the lockwire pliers lol I got good at in my crew days. It was nice to show the kids how’s it done once I was a test pilot, those impossibles got me a few cases of beer! |
BVM carries it on their sight. So does Dreamworks.
https://cimg4.ibsrv.net/gimg/www.rcu...17a70b10eb.jpg
Thank all for the prompt replies, it has been years since I got my last roll of SW, so long ago, I don't recall where I got it from, I used up my last inch on my last project. 020 is what I'm looking for, it's a good gauge to secure the UATs sox, fuel lines, airlines. About the twister pliers, I got me a HF ones around 2002 and have done dozens of jobs with it, agreed, not the best quality but it is still working for me, if I was looking for a new one, you bet your jets that I would buy one of the good quality ones, the screw driver with a hole is an excellent idea, very useful in those tight, hard to get spaces, I know :) Hey! newbies, take notes, very good info been posted here. Thank you all for taking the time to replie to my question. |
Originally Posted by FenderBean
(Post 12499198)
Army crew chiefs do it all by hand, not allowed to use the lockwire pliers lol I got good at in my crew days. It was nice to show the kids how’s it done once I was a test pilot, those impossibles got me a few cases of beer! At the time I was having my issues with learning how to make it look neat and the older guy who owned the FBO, used to come out, look at some of my early attempts and he'd just cut the wire in half. He told me that safety wire was like your signature; if it is nicely done, you can pretty much figure everything else was done the same way. Over the years I spent with GA on everything from trainers to Gulfstreams, that proved to be true almost all the time. |
| All times are GMT -8. The time now is 06:17 PM. |
