RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Lumpy Hysol (https://www.rcuniverse.com/forum/rc-jets-120/11661692-lumpy-hysol.html)
peter w h 03-06-2019 11:20 AM
Lumpy Hysol
I am having problems finding a supplier that has smooth 9462 Hysol.
The last 3 orders received (all from different suppliers) has yielded a very lumpy (white side) adhesive.
JoelP 03-06-2019 12:02 PM
I put mine in a cup of hot water and it gets smooth and sets up normal.
Andrew Bird 03-06-2019 12:09 PM
I've had the same - mine's all been lumpy recently. Still seems to work fine but has been a bit more difficult to make clean joints with.
peter w h 03-06-2019 01:33 PM
Three cheers to JoelP
I just tried it and I will be darned it works perfect. :D
sysiek 03-06-2019 01:38 PM
I stopped using hysol after finding the six10 epoxy glue by West system and I think it is much better than hysol.
Steve Collins 03-06-2019 05:14 PM
That lumpiness is usually due to age of the resin. I have found that it is still usable and does not appear lumpy once cured.
JimBrown 03-12-2019 11:29 AM
As JoelP mentioned, warm it up in some hot water. Or, since I'm too lazy to get said hot water, I just heat it up a bit with my heat gun (the one I used to use for ultracoat). But, not too much!
...jim
jason 03-12-2019 02:50 PM
Heat makes it like new again. It also stays good for the same time a new tube would. Also works on any epoxy. My Zap epoxy are always in the microwave for a few seconds. The UK distributers of Hysol told me of this "relifing" process about 15 years ago.
mr_matt 03-12-2019 03:38 PM
I agree. I ran out of E-40 (the grey Loctite/hysol) and I used a new tube of the six10 that I bought a long time ago. I was very impressed and I think it is maybe a third of the price. I need more practice to not waste so much with the much bigger plunger and tip (it is a caulking gun) but overall it is excellent.
patrnflyr 03-12-2019 03:48 PM
Be careful warming epoxy up in the microwave. It produces fumes that aren’t easy to detect and can be really bad for you.
sysiek 03-12-2019 05:23 PM
https://cimg1.ibsrv.net/gimg/www.rcu...c2f0cec495.png
Hi you could use the regular small size mix tubes just install them inside the plug ,I’m usually mixing the glue on the side with wood stick.
JoelP 03-12-2019 05:50 PM
I never use the mix nozzles because you can’t see what’s going in the nozzle. I always dispense on a paper plate and mix like regular epoxy. I have never had a hysol glue joint fail!
causeitflies 03-13-2019 12:33 PM
If the nozzles weren't so wasteful I would use them. I've never used Hysol but have used West Six10 for years. Lately I've been using the Jamestown Dist. version too.https://cimg6.ibsrv.net/gimg/www.rcu...838ea413f.jpeg
YellowAircraft 03-17-2019 05:28 AM
Hi,
What's the cure time like on that 6-10? Is it thick enough to hang upside-down without sagging like Hysol 9462?
sysiek 03-17-2019 06:58 AM
Originally Posted by YellowAircraft (Post 12510997)
Hi,
. About 24 hours for complete cure and absolutely no running and sagging in all positions.
causeitflies 03-17-2019 08:54 AM
Six10 also has the unique property of liquefying when stirring or adding pressure. You can wet out fiberglass cloth with it.
Dave Wilshere 03-17-2019 01:51 PM
Flush the epoxy out of a Nozzle sometime, you waste so little I stopped worrying about it years ago. The insert fills most of the small tube. Squeezing the glue into many joints is what makes them so good, fillets are just a bigger waste of glue and added weight.
