RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Question for Cortex Experts (https://www.rcuniverse.com/forum/rc-jets-120/11662740-question-cortex-experts.html)
SECRET AGENT 03-29-2019 05:30 AM
I have a Cortex (the old version, not the pro version) on an Avonds F-16 set up for taileron only. Everything works as they should to input commands from the transmitter. But, when the Cortex is on and I manipulate the jet to test the gyro reaction, both stabs react together on elevator changes but on aileron deflection only the port side stab reacts to changes. Is this normal? I don't see why it wouldn't work, just curious if both stabs should be reacting and I have something wrong.
Any thoughts?
F1 Rocket 03-29-2019 08:03 AM
If the taileron mix was active when you did the Cortex programming sequence it should work. If not, redo the programming. Make sure the taileron mix is active and that you wait for the first double green LED flash, then start the stick movement sequence.
Danny
BarracudaHockey 03-29-2019 09:04 AM
Can't get any more expert than that.
SECRET AGENT 03-29-2019 10:22 AM
Yes, the taileron mix was active before I conducted the gyro learning sequence. I even relearned it numerous times to make sure I wasn't doing it wrong.
I've been told by a friend (offline) that I need to plug the Cortex into a computer and using the Cortex software change the Cortex programming to "taileron" for it to work correctly.
Do y'all concur?
BarracudaHockey 03-29-2019 11:08 AM
When you do the teaching process, if both outputs are plugged into the Cortex, and the mix is active, when you move aileron it takes note of which ports receive aileron input, and when you move elevators it does the same. You shouldn't, as far as I remember, have to fiddle with the software for the Cortex.
SECRET AGENT 03-29-2019 11:32 AM
Yeah, it's very strange. The tailerons work normally when the sticks are moved, and the gyro moves both stabs when correcting pitch, but only the port stab when correcting roll.
F1 Rocket 03-29-2019 02:33 PM
There is no special taileron setting in the software. The system learns the mix during the programming sequence . It’s possible you don’t have enough travel on aileron for it to pick up the one servo. Try increasing the travel a bit and re-teach the system,
Dsnny
SECRET AGENT 03-29-2019 03:38 PM
I'll give that a try and let you know, thanks for the suggestion Danny.
SECRET AGENT 03-30-2019 04:15 AM
Danny, you were 100% correct, I increased the travel, re-learned the gyro and it works perfectly now. Thank you so much for your help with my issue, I really appreciate it.
Mike
BarracudaHockey 03-30-2019 04:34 AM
Can I postulate that if your throws weren't enough to get the Cortex to pick up the ailerons correctly that you may be mechanically setup not to your best advantage?
SECRET AGENT 03-30-2019 05:44 AM
Let's hope not.
tp777fo 03-30-2019 06:07 AM
No you're in good shape. PA engineers all that to perfection. I didnt think about teaching at 100% then backi ng off. Glad you got it fixed
Tip22v 12-08-2021 08:31 PM
I’m hoping someone is still monitoring this thread. I want to setup my Flex Jet Pro so that the tailerons only activate when the flaperons are fully deployed but so far as I know there is only one learning process for the cortex. I’m assuming this config is not possible? Thx
LA jetguy 12-08-2021 11:13 PM
I used flight modes to achieve that .. then you can set different gyro gain for each flight mode. I have this setup on my F16.. when flaperons are in landing mode… elevators will become tailerons..
David
Bob_B 12-09-2021 02:11 AM
Are you a Jeti user? If so I can send you my Tx file.
Teach the Cortex when flaperons are in the up position. (Pure ailerons)
Tip22v 12-09-2021 06:06 AM
Thanks, yes I’m a Jeti user. So, teach the cortex with the flaperons in straight aileron mode, which is how I have it now, when I switch the elevators into taileron mode with the flaps deployed I assume roll stabilization from the gyro is done via the flaperons because the cortex does not know about the taileron config?
Tip22v 12-09-2021 06:10 AM
David
I’m using flight modes now with different gains for each flap setting with 25, 35, 45 for flaps up, mid, full down, respectively. Do you notice any difference in handling when you switch to tailerons?
Bob_B 12-09-2021 06:16 AM
Yes the ailerons will still compensate for outside roll inputs when in the full flap position.
Bob_B 12-09-2021 06:19 AM
My Gain values are 30/50/80, the roll function is not as quick in taileron mode. I go full flaps on my downwind leg, you could always wait until you turn final to lower the flaps completely.
LA jetguy 12-09-2021 07:49 AM
Yes helps banking during landing mode.. I also assigned a switch to have tailerons active during cruise mode.. that will a full scale “tail skid” during banking
I named that switch which is another flight mode “High Rates”
David
Tip22v 12-09-2021 01:51 PM
Thanks for the help. When you switch to tailerons in high speed flight do you also keep your ailerons active? Same question when the flaperons are fully deployed and you activate tailerons, do you keep your ailerons active too?
Bob_B 12-09-2021 03:37 PM
I only use flaperons and flaps for take off and landing. When the flaps are all the way up it is strictly ailerons and elevator
Tip22v 12-09-2021 09:22 PM
Thanks so much for the video, that answered all of my questions:)
LA jetguy 12-09-2021 10:21 PM
https://youtu.be/vgW5xr4a14Q
Yes.. I have the exact setup …. But have a switch to turn on and off ailevons during cruise (normal) flight mode.. during landing and take off the ailevons are active
Bob_B 12-10-2021 01:58 AM
I’m still flying that exact setup a year later. It is a great flying model btw.
You will find that when you drop the gear for landing the model slows considerably. Enjoy!
