Powerbox Mercury SRS & JR RG812BPX DMSS receivers
Hi, guys,
I have the Mercury installed in one of my jets with dual JR RG812BX receivers. Everything works fine, easy installation SRS (Patch leads from both receiver's X-Bus ports directly to mercury's RX1 and RX2 ports). Now, I want to make installation for another jet with Mercury, but this time with 2 JR RG812BPX receivers which includes direct battery cable. Again, 2 patch leads fron receiver's X-Bus ports directly to Mercury's RX1 and RX2 ports..... The thing that makes confusion to me is, where shall I connect the direct battery cables from the receivers? I assume that, since the patch leads from the X-Bus port of the receivers to Mercury gives them power supply as well, right? I'm a little lost at the moment, so every info will be much appreciated. Thanks, Makis. https://cimg1.ibsrv.net/gimg/www.rcu...3dc6e4123f.jpg |
I believe that all battery connections will go to Powerbox and receiver power will be supplied via X-Bus cable. I use the JR Axis gyros in pylon racing planes and plug the single battery into the gyro which then backfeeds the power to the Rx.....has worked fine this way for years
Originally Posted by cbk07
(Post 12595256)
Fully agreed, it was my first thought, but where on the Mercury must connect the 2 receiver battery cables? That's my problem..... |
I do not think you will connect them to anything. Receiver power should come from Xbus cable (unless I am mistaken). The only reason to use the receiver cables is if you are plugging servos directly into the receiver(s). I will try to verify this for you on a bit
Just put a cap over the Deans so it does not short out. All the positives and negatives are linked.
(Post 12595266)
Originally Posted by Dave Wilshere
(Post 12595297)
