RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   400mm EDF Project (https://www.rcuniverse.com/forum/rc-jets-120/11682563-400mm-edf-project.html)
SkyersJet 09-09-2020 03:20 PM
400mm EDF Project
I've been working on 3D printing a 400mm diameter EDF. Most of it is printed out of PETG on my Creality CR-20 printer. The motor (15kW 600kv inrunner) is attached to a gearbox in order to provide enough thrust. So far I have reached approximately 18kg thrust during testing.
https://cimg5.ibsrv.net/gimg/www.rcu...b96bea626.jpeg
https://cimg8.ibsrv.net/gimg/www.rcu...62b29d535.jpeg
https://cimg0.ibsrv.net/gimg/www.rcu...d3c90e63c.jpeg
Halcyon66 09-09-2020 05:30 PM
Vasyfan is making 250mm and 390mm monsters running over 70kg with up to 50kw, and eye popping amps.
In most cases you want high rpm to get the mass flow and high thrust numbers, yet you then have to have very strong blade mounts. In his case they are individually molded carbon fiber blades
https://www.vasyfan.com/en-gb/edf-plus
250 mm and controller close to a big Jetcat in prices.
Regards,
SkyersJet 09-10-2020 04:53 AM
Regards,
And they cost thousands. Thrust alone isn't a good comparison. 70kg at 50kW is 1.4 g/W efficiency therefore at that level of thrust the efficiency drops to almost half that of mine (2.4g/W).
Nige321 09-10-2020 12:01 PM
OK, I'll bite...
What's it going in...??!
Halcyon66 09-10-2020 01:01 PM
4 Attachment(s)
Efficiency is a pointless term in model aircraft, rc turbines are not efficient they just burn as much fuel as they can get. Electric systems are not much better.
As already said they cost $$$ yet for their output they actually produce more thrust than a P500 pro, and they are around 10k € for the fan unit and brushless controller.(https://www.mgm-compro.com/electric-propulsion-systems/)
There is a reason EDF run at high rpm, while gearing the unit will produce torque, at a certain speed the fan unit will act as a brake. Also printed blades will fail very quickly due to load and flex.
Here is a 400mm in igs you can easily modify and work with if you want.
https://cimg7.ibsrv.net/gimg/www.rcu...185a701100.jpg
In thrust we trust :-)
Regards,
SkyersJet 09-10-2020 06:35 PM
Regards,
Efficiency is not pointless. I don't get what your point is exactly, I post a DIY project and you reply that some company is selling the same thing for £10k. That's like me posting a home built car project and you telling me to buy a BMW.
SkyersJet 09-10-2020 07:02 PM
Originally Posted by Nige321 (Post 12631083)
OK, I'll bite...
It's not for anything specific, it's a research project to a) develop an EDF bigger than existing ones (I actually started this before the 395mm carbon EDF that that other poster mentioned was released, you can check my YouTube channel history) because bigger = more efficient, b) to investigate low cost FDM manufacturing methods for EDFs (I did the stress calculations), c) to investigate using cheaper lower-torque motors run via a gearbox (without the gearbox I'd have had to have used a TP100 which is double the price and even then it wouldn't have had quite enough torque and finally c) to enable the use of high-lift intake rings (I've been doing research on intake rings for a while and I found that they give more benefit on a larger scale. Ideally I'd like to use it in VTOL applications but it isn't specifically for any craft.
Halcyon66 09-10-2020 08:19 PM
I simply made the statement that there were some huge fans out there, Schubeler has also been making 20+kg with a 195mm for how many years?
Vasyfan was making custom large scale for yrs and yrs, the 350s came out in late 2017 from memory. He has also made even bigger sizes for custom apps.
Your website is suspended and your YouTube channel was started in Feb so not sure of why your stating you were making these yrs before anyone else?
Regards,
SkyersJet 09-11-2020 08:17 AM
Originally Posted by Halcyon66 (Post 12631171)
I simply made the statement that there were some huge fans out there.
Along with "your blades will fail" "efficiency is pointless" and you posted a CAD model of a fan and told me to use that instead.
I simply said I started the project before I saw any EDF of this size advertised. I don't know when that manufacturer started developing his 395mm, he could have been developing 5 years ago for all I know. All I know is he posted the YouTube video showcasing it in February so before that I did not know that there were any of that size.
Anyway I don't know why you keep saying my project isn't as powerful as a £10k professional carbon EDF. As I said this is like me posting a kit car build and you saying that it isn't as powerful as a Mercedes E-Class.
Halcyon66 09-11-2020 05:02 PM
"Here is a 400mm in igs you can easily modify and work with if you want"
Not sure that is forcing you to do anything, was just trying to help get the thrust up. Now I know that your only concern is price and not thrust I totally understand what you’re not trying to achieve.
Yes the others are very expensive yet they are at the top end of what is possible with those inlet diameters. I talked of costs in relation to Vasyfan vs. turbines in the same class (50 kg + ), yours was not included in that comparison.
Your comment regarding kit cars is mute as there are numerous "kit cars" that cost far less than a Mercedes E class (???) that have truly monster performance. 572 crate at 700hp can turn anything into a beast and not break the bank.
Regards,
SkyersJet 09-11-2020 05:34 PM
Regards,
The thrust is lower because I put less power in. I don't know why you assumed I needed a better fan.
Well of course if you throw a big block into any old frame it's going to be powerful but will the car be reliable? Likewise I could hook up a 50kW motor to my EDF and it might produce 40kg before the blades give up. That's not reliable. I'm aiming for 20-25kg of reliable, efficient, low-cost thrust.
SkyersJet 09-30-2020 03:37 PM
I've been trying intake bells to improve efficiency. Here is the first attempt (well third, the first two were so bad I won't even post those)
http://www.youtube.com/watch?v=GGIXO...ature=youtu.be
Halcyon66 09-30-2020 06:09 PM
https://www.wattflyer.com/forums/forumdisplay.php?f=12
https://www.rcgroups.com/electric-du...n-jet-talk-12/
Regards,
SkyersJet 04-25-2021 04:10 PM
Here is the latest progress. I built a new test stand which is a trolley on a pull scale:
There was an accident:
But I got it working again:
apaw 07-24-2024 04:50 PM
Sorry, for replying to an older thread.
I'm amazed at your project! Spellbound might also be mentioned.
Please: Any updates?
What kind of RPM are you running on these?
I used to design cardstock models that flew using EDF. Eventually selling a SR71 model on eBay that was 57" long.
The cardstock models are designed to use different power options.
Then I bought a Vans RV-6 and spent several years flying it around. Designing slowed down to other types of of power, Estes rockets, rubber band and compressed air, one project was powered with a Hobbyking pulsejet.
Haven't done much with EDF units since around 2010. After some searches, things have changed, technology is a wonderful thing, have lots to learn about these changes.
For years been designing a full size EDF aircraft to actually fly in. Been waiting on technology to catch up. A recent search found the VasyFan VF-570.
Exactly what I've been waiting for.
Purchased and received my VasyFan VF-570 from Timis in Italy.
Really curious to see your project, I would like to know more please.
Mike
SkyersJet 09-23-2024 01:57 PM
Hi Mike.
I took a break from the project but it still exists. I released the files for a smaller version on Thingiverse. I have not yet tested it however.
Link https://www.thingiverse.com/thing:6211589
The large one in the videos spins under 5k RPM. The small one is predicted to spin at 15k RPM. There was a website explaining more but it expired. I will make a new website in future. In the meantime, enjoy my Youtube channel!
SkyersJet
Sunilazad 02-21-2025 01:29 AM
Request
Please tell me it's rpm...@ when it reaches 18kg thrust..
Actually sr I already studied about 400mm edf...
Please reply soon as possible sr...
