Digitech CG Wizard
I need a little help here.
I purchased this CG system after some great deliberation between the two top contenders. The system connects to your phone for a display. It has been working very well to this point. I got it out for the first time in a couple of months and the system will no longer connect to my phone. I used the same process and setup I was using with success to this point. An Android 6 phone. The battery for the meter is fully charged. I use the appropriate sequence to start it up. The laser turns on, but the system refuses to connect. I have gone to the Digitech site and cannot find a help line to contact. I have done everything I can think of, so help! John |
Not sure if your on Facebook....but Digitech is very response there....
I have been resisting getting involved on Facebook as the wife spends enough time there for both of us, and otherwise I probably wouldn't get any building done. I guess if that is my last resort I'll go there.
John |
Digitech is also here....not sure if you tried yet...look into the CTU tread....and message him.
What is the CTU thread?
Originally Posted by john491
(Post 12632325)
Thank you.
John |
Yeah, Sandor responded pretty quickly on fakebook.
I don’t think I could have got my CTU to work w/o it. I made up a profile as a 14 yo Thai girl on fakebook. Try it and make up some weird stuff! Exploit fakebook as fakebook is exploiting you. |
| All times are GMT -8. The time now is 03:40 AM. |
