Wing structure question.
I have a replacement composite wing for one of my jets. I happened to notice that there was a decent amount of movement along the whole top of the wing. When I borrowed a camera and scoped it, I can see about a 1/16 to a 1/8th inches gap between the lengthwise vertical wing structure and the skin. There is also asimilar gap between the wing ribs and the top skin. Even a couple in the front. Almost like the supports were a bit too short or not enough glue was used. This includes the landing gear area also and some point at the leading edge. This lack of attachment explains why the wing top skin is floating up and down so much.
Because this gap runs the length of the wing the majority of the supports I will not be able to reach to add additional glue. Is my understanding was that the top and bottom composite skin being attached to the vertical supports are what gave the wing its strength. Kind of like a engineered joist. So I am not sure how structurally sound this wing would be at 200mph or bank and yank turns. Nor do I want to unnecessariky risk my turbine and electronics. Therefore I am seeking the advise of some fellow builders. Do you guys think this wing will be safe? Thanks Agrav8ed. https://cimg8.ibsrv.net/gimg/www.rcu...894eaf3c9d.jpg This is the landing gear area. You can see a lack of glue and a large gap between the support and the wing skin. https://cimg1.ibsrv.net/gimg/www.rcu...30f75a67ab.jpg This is near the wing tip, as you can see, the top skin is still not attached https://cimg9.ibsrv.net/gimg/www.rcu...eb5454f676.jpg Gap between the wing skin and the lengthwise support. https://cimg0.ibsrv.net/gimg/www.rcu...697033c30d.jpg Gap between the vertical ribs, lengthwise support and the wing skin |
What kit?
Originally Posted by tp777fo
(Post 12677006)
What kit?
Thanks, Agrav8ed |
I would not trust it. If you can see movement on the ground imagine what it would do in the air.
Contacting the manufacturer is the way to go. I think any reputable kit manufacturer would replace that in a heartbeat.
Hi Agrav8ed
good thing not to fly this wing. Both wing skins must bond with the internal structure. When you build a wing mold, tuning up the perfect internal structure takes a lot of time - trial and check and again and again - so that the fit is perfect and the gaps between skins and the structure are minimal. I wonder what the manufacturer will tell you. I received a SkyEmaster F-15 EDF 3 weeks ago. First thing I did was to check the internal wing structure with an endosocopic camera. It was flawless, however some other spots could have become some more building time;) |
Yeah, I was questioning the structural integrity of the wing myself, hence my post. Without the top skin being bonded to make a cohesive structure, there is not alot of support for the internal structures or the bond with the bottom wing skin. It's good to know I was not overreacting.
Agrav8ed |
That wing should have never left the factory. !!
In the first picture it looks like it delaminated. In the next few looks like it was not a good fit. DON'T use that wing. It is not a matter of if it will come apart as apposed to it WILL come apart.
Hope the manufacturer steps up on the wing and sends you a properly built wing. Just my 2 cents. Joe |
Is there a QA sticker & number on the structure ?
At first i thought delamination, but when you look at the 2nd photo you posted, one side of the rib has a good contoured joint, so it looks to me like the rib and wing skin never made contact. Tough one to fix yourself, hope the mfgr makes it right for you with minimal waiting
Originally Posted by scoeroo
(Post 12677135)
Originally Posted by patf
(Post 12677147)
I appreciate everyone replying and weing in with their opinions. I was not comfortable with the wing integrity and wanted to make sure I was not overreacting. Agrav8ed |
I saw the same thing on a Krill 3m aerobatic model someone in my local club bought. They had skipped putting adhesive on all but the leading and trailing edge joint. It’s impossible to fix. They gave him new wings.
Just spoke to the manufacturer. They were very receptive to the issue and we are working on replacement options so it looks like things will be handled. I appreciate everyone's feed back.
Agrav8ed. |
That wing is an accident waitin to happen -
I’d be curious to know the aircraft manufacturer also (not to bad mouth them), only to be informed to look out for issues if I either have or order the same aircraft. Mistakes happen, and all we can do is keep an eye out for any issues and notify the manufacturer for a resolution. I’m glad it sounds like this is working out for you and good for the company for stepping up to the plate when it matters.
Easy fix, rather than waiting for the replacement. Just fill it up with some ply bits and with the long brush fill in with epoxy or any bond agent, like gorilla glue, etc. Don't blame manufacturers, it is pilots responsibility to make sure the ARF models don't fall apart.
I have found similar problems with numerous ARF models over the years, I have covered few cavities and poured in pint of PVA , gave it a good gargel and shake, drained it out and let it dry, good as new, LOL. |
Originally Posted by Joseph Frost
(Post 12677282)
Well, If I buy an ARF turbine jet ((kit) what it still is somehow) with composite wings, I expect the internal structure of the wing to be built correctly. |
To me it looks like the mold halves weren't fully closed. The lack of prep on the bond line is an issue as well.
Originally Posted by cetigershark
(Post 12677294)
Hi Joseph
Well, If I buy an ARF turbine jet ((kit) what it still is somehow) with composite wings, I expect the internal structure of the wing to be built correctly. I just hope for his sake it doesn't take another 10 months to get the next replacement parts. |
Like what happened to the Carf Extra 330XL when it had a flutter issue and it took quite a while for the replacement wings to arrive.
But Carf did fix the issue, the company does stand behind their product. |
| All times are GMT -8. The time now is 07:13 PM. |
