RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Tailpipe question (https://www.rcuniverse.com/forum/rc-jets-120/11690800-tailpipe-question.html)
powerjets 06-01-2021 05:40 PM
Tailpipe question
On a straight dual wall tail pipe, isnt the outer supposed to be extending past the inner pipe for airflow purposes?
my outer pipe is shorter at the rear, is this ok ?
im trying to upload a picture.
any advise on this ?
powerjets 06-01-2021 05:42 PM
https://cimg5.ibsrv.net/gimg/www.rcu...3e1d09d696.png
Dave Wilshere 06-01-2021 08:49 PM
That won’t work. Does the outer slide?
powerjets 06-02-2021 02:12 AM
No
no, it's welded
Dansy 06-02-2021 03:08 AM
Originally Posted by powerjets (Post 12680356)
While it’s not the norm, this could work depending on where the supporting rib is….with a really deep tail cone…
Len Todd 06-02-2021 04:04 AM
How far does the inner pipe stick out of the fuse/tail cone? I had a similar issue with a replacement pipe and the inner was just too long. So I cut the inner off and they both came out even at the end of the tail cone.
powerjets 06-02-2021 08:03 AM
It's not so much the fit, that's ok, I can keep the end within the nozzle.
im more concerned about the airflow not being sufficient between the pipes.
Dave Wilshere 06-02-2021 09:56 AM
The question was more if there was a moulding of some sort to complete the outer?
powerjets 06-02-2021 10:24 AM
Hi Dave,
no this is the complete pipe, nothing else with it.
does the air between the pipes even move much like this ?
joeflyer 06-02-2021 03:41 PM
The outer pipe should be about 10 mm. longer that the inner at the exit. That way gasses exiting the inner pipe create a vacuum that draws cooling air into the front of the outer pipe. The pipe as pictured might work but would run hotter than if it was made properly.
It's hard to tell from the picture but it almost looks like they welded the bellmouth onto the wrong end of the pipe. If it were me I'd contact the disributor/manufacturer and request a corrected pipe. If you had a picture of a proper pipe from their website that would help.
Joe
powerjets 06-02-2021 03:56 PM
That's exactly what I was thinking
Dave Wilshere 06-02-2021 07:51 PM
The inner protrudes each end, so it won’t work either way. What airframe?
powerjets 06-03-2021 02:14 AM
It's a replacement for a top RC Cougar pipe
