RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Skymaster PC-21 flap setting and control throws (https://www.rcuniverse.com/forum/rc-jets-120/11710358-skymaster-pc-21-flap-setting-control-throws.html)
Bigells 02-25-2024 09:28 AM
I am setting up my Skymaster PC-21. I have read the build manual but I have questions on the flap settings. The manual has one setting for flaps which is 38 mm. This seems not quite correct as I usually use two setting , one for takeoff and one for landing. The 38 mm setting does not seem to fit either positions. Could the group please share what flap settings they are using on their PC-21, also if you could share the aileron and elevator settings too.....thanks
https://cimg6.ibsrv.net/gimg/www.rcu...0b70b38364.jpg
David Jackson 02-26-2024 07:56 PM
If you have the PC-21 manual from Skymaster, use their suggested settings for all the control surfaces for your initial flight. I have used their recommended settings on the three SM PC-21s that I have owned..
https://cimg7.ibsrv.net/gimg/www.rcu...3d91f6beec.jpg
Bigells 02-28-2024 04:12 AM
Dave
The manual give a vale of 37 mm for the flap settings. Are you using this value or do you have different settings....thanks
Steve G
