RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   servo controlled ball valve? (https://www.rcuniverse.com/forum/rc-jets-120/1237735-servo-controlled-ball-valve.html)
adryan 10-29-2003 04:21 PM
Hi,
I'm installing my equipment in the Roo and have a question. In some early versions of JET International I saw they used a servo controlled ball-valve as a kill switch. I'm using the jet-cat, but is it still necessary to install such a servo controlled kill switch?
Most pictures of installation I see posted don't include such a switch.
Rgds,
Adryan
UK Flier 10-29-2003 05:11 PM
RE: servo controlled ball valve?
1 Attachment(s)
Good question, I am looking for the same thing.
Found this in the festo catalogue which looks as if it might have a long enough arm
for a servo connection, but it only comes in 4mm fitting, I need 3mm.
http://catalog.festo.com/data/CAT_PD...04/4_08-12.pdf
CJ2002 10-29-2003 05:58 PM
ORIGINAL: adryan
Hi,
...is it still necessary to install such a servo controlled kill switch?
Rgds,
Adryan
Hi Adryan,
In England, the BMFA uses the GTBAs Code of Practice as the authoritive document, and it states:
"3.3 The fuel line must have a mechanical shut-off valve, in the delivery line from the fuel tank(s), or a switch to isolate the electrical supply to the fuel pump motor, which can be manually operated in addition to any servo control, and which is readily accessible."
Cheers,
Dick
England
UK Flier 10-29-2003 06:10 PM
so which one do you use Dick?
CJ2002 10-30-2003 02:17 AM
ORIGINAL: UK Flier
Just the standard manual shut-off valve that UKFLIER has highlighted....not servo controlled (it's a back-up just in case the electronic side of things fails - also useful to stop fuel going to the engine during refuelling, etc).
Do a search for Festo and, from there, find where the nearest distributer is to you...or, if you're in the UK, go to Motors and Rotors website and buy one from Dave Wilshere - he stocks them.
Cheers,
Dick
England
Robrow 10-30-2003 12:54 PM
If you ar not too restricted on space you can put a Festo 4mm/3mm straight reducer connector either side of the 4mm ball valve.
Rob.
Topgun2mo 10-31-2003 08:04 AM
I think it would be very wise to add a servo to the manual valve to have the capability of shutting off the fuel flow to the pump. I have seen an ECU malfunction in the air, the fuel pump continued to run and the results were not a pretty site. The servo could be mixed with the throttle trim so that when you shut down the ECU the servo also closes the fuel valve. David Gladwin outlined this in one of the Jet International Articles. He used a cable that can only close the valve. The valve had to manually reopened.
I think this is a real smart thing to do...could possibly save an airplane.
cairoman 10-31-2003 01:07 PM
1 Attachment(s)
This is what I use as a manual/servo controlled bypass valve in all my airplanes. It is what Simjet recommended for use in the old pre-electonic fuel valve systems.
Chris
Woketman 10-31-2003 03:08 PM
Cairoman, I'd love to get some of those valves. Do you know of a source? Thanks.
cairoman 11-01-2003 12:00 AM
Hi Mark,
It's a Festo three-way valve, Type:33003 KH/O-3-PK-3 for 0-115 psi. I bought a bundle of those, four years ago in Toronto from Festo Canada.
Chris
UK Flier 11-01-2003 12:34 AM
Chris that is brilliant, Just what I was looking for as well.
John
cairoman 11-01-2003 06:17 AM
Hi John,
Glad, I could contribute with something here. Please note that these valves do not last too long. I change mine once a year. The good thing about those, is that they will not put stress on the pump, just by-pass the fuel supply.
Chris
Woketman 11-01-2003 08:12 AM
Why don't they last long? What craps out? Thanks.
cairoman 11-01-2003 09:29 AM
The rubber stoppers inside them become hard after prolonged exposure to our fuels (turbine oil).
Chris
Dave Wilshere 11-01-2003 06:21 PM
Guy's
MAS make a nice servo operated shut-off valve that's small and neat.
The Festo ball valve can be servo opertated with a cam arm-Tom Wilkinson showed one in his original Kangeroo review in RCJI
Dave Wilshere
