Hitec Servos
Has any one had any experience with the new digital hitec servos? Just wondering, I was thinking of putting the HS-5645mg in a hot spot any comment good, bad, indifferent, would be appreciated.
Hitec's
Hi Jester.
I am about 3 weeks away from the maiden flight with my Hotspot :D , powered by a TJT-3000. I have a pair of Hitec 5945MG's for the elevons. As I recall they were in the same ballpark as the JR 8411. This servo was a bit cheaper than the JR and it included a real nice aluminum servo arm (1 hole is threaded) Upon comparison, the Hitec seemed to have a bit less backlash in the gear train :) (both right out of the box) Most of the remaining servos are also Hitec's, other than the Wing-Maxx's in the fins. I am running a pair of 6Volt packs with a MH voltage regulator. The gear is Robart, wheels/brakes by Trim. We shall see... Kelly |
I got some
My roo is almost ready to fly I am using them on my rudders and elevons so I hope the work :p
david |
Hitec Servos
:confused: Which hitecs are you using for your rudders in your hotspot?
| All times are GMT -8. The time now is 02:44 AM. |
