DL Cyclone control throws? help
Hi all,
I have a DL cyclone, the first one, not the 3, and i was wondering what you guys are using for control throws on it? I have one witht the sport wing, and no flaps, i assume i will be using flaparons. And if you can give me the throws in inches that would be great too, Thanks, Nate |
Cyclone
I think your best bet is to check with Yves at DL. I do have a Cyclone I , but I dont remember the throws. When I built mine, I asked Yves and did what he said. It flies fine at the recommended rates and is not pariticularly touchy or sensitive.
Cyclone throws
from the manual:
Aileron 1/2" up and down Elevator 7/16" up and down Rudder 1/2" left and right Measurement take from outer edges of moving surfaces You will need to use flaperons for landing to slow it down |
| All times are GMT -8. The time now is 07:44 PM. |
