RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   BP Vector Fan (https://www.rcuniverse.com/forum/rc-jets-120/1375950-bp-vector-fan.html)
B1Driver 12-24-2003 05:58 PM
BP Vector Fan
Anyone have any experience with this? I got it as part of a supreme Regal Eagle kit I bought and cant find info about his fan. It looks like a tractor setup like a dynamax/ramtec. Any info would be appreciated. Thanks and Happy Holidays.
Luis
B1Driver 12-25-2003 01:44 PM
RE: BP Vector Fan
Not surprised alot of people havent heard of the BP vector fan, but I thought one of the old heads would have some sort of input.
MiragePilot 12-25-2003 11:09 PM
RE: BP Vector Fan
I know a guy who tried to use that fan in one of the BP Sabres. It was 100% completely useless and not even heavy enough to use as a boat anchor. Do yourself a favor, throw it in the woods immediately and buy a Ramtec/Dynamax....at least then your odds of success will possitive.
Regards,
Peter
pecojets 12-26-2003 10:12 AM
RE: BP Vector Fan
dont confuse the quick-build fan with the vector fan.!!
the bob parkinson quick-build ( plastic) f-86, cheetha and jaguar( i got the jaguar) use a clear plastic fan body , with a wood angine mount , no stator blades and a dynamax impeller. it stick to the fuse sides with a plastic mounts. if you have one of this ! dooont use it ! but if you have a vector fan , that is a more convencional desing with plastic engine mount that hodls a small tank behind the engine and has stator blades you can use only because you already have it , and you can save some noney. if you have to buy one ,for grass field use a byro-jet for others use the dynamax. . the reagel eagle can use it both
luck! alfred
B1Driver 12-26-2003 02:41 PM
RE: BP Vector Fan
Yea, I got stiffed...got the clear plastic shroud with the wood make it yourself mounts and the dynamax impeller. (is it really dynamax) Anyway..off I go to try and find a ramtec fan for this thing. I was hopeing that I wouldnt have to spend more on it, but I guess I do. Thanks for the replies guys.
pecojets 12-27-2003 09:15 AM
RE: BP Vector Fan
since you have the dynamax impeller , wish is the most expencive part of the fan , you can order from jet model products the rest of a dynamax fan systems ,for less than $ 100.- bucks
alfred
B1Driver 12-27-2003 01:08 PM
RE: BP Vector Fan
Peco,
That is an excellent Idea. Thanks for the info!!
After looking up the dynamax fan on JMP's website, the unit I have is different....mine only has 9 blades where the dynamax has 11. What the hell do I have LOL.. Oh well, thanks for the info anyway.
Luis
rocketman-RCU 12-27-2003 04:48 PM
RE: BP Vector Fan
Sounds like you have the BP Vector fan. Does it look like 9 cut off master airscrew blades riveted together? You can't use that with a Dynamax fan. You will need to buy a complete fan system.
Gary
B1Driver 12-27-2003 06:20 PM
RE: BP Vector Fan
Yup...looks like the 9 blades were cut. Yea, im looking for someone with a Ramtec that he wont need anymore and is willing to sell for cheap :) Thanks for the replies guys. I guess nobody had any luck with this makeshift fan unit then. I can see how a slight missalignment would prove fatal with it. Thanks again.
Luis
jedijingle 12-28-2003 03:25 AM
RE: BP Vector Fan
yep, throw that POS away. there were two versions, a 9 blade and an 11 blade. made with grish tornado props cut down. mine produced good thrust on some days at certain moments, but not enough to fly. I now have a dynamax fan and a yellow aircraft F18 single exhaust thrust tube in it. works and fits great.
