RE: Bringing back the Tango...
I will post pictures of what is left of my Tango asap. This was my frist jet crash.
I will talk to him and find out what happen.
In the mean time, what happened? Was there any video? Mike, I'm sorry you lost your plane.
Thanks I just got the jet to far out from me and could not tell what it was doing and the sky was dark and the jet turned black. I tryed to get it back to me ,but it just did not work out so, I had to shut down the turbine, and watch her go in. Then we look for two hours and then found her in a parking lot of a old shut down plant.
Crap, that's a bummer. I'm only 31, but my eyes just aren't as good as they used to be. I find that I'm more comfortable flying lower and closer than some pilots fly. I think the tango is a glorified stunt prop jet on turbine power. I plan on really exploring some tight close in high performance flying with it. I hope you got enough flights out of it to at least have been satisfied with the airplane.
Sounds like a big loss, did the turbine make it? |
Mike,
Forgot you told me it was an orientation issue.....For some reason just the dead stick part stuck in my head [sm=bananahead.gif]....Think I need my Ginko Baloba [sm=spinnyeyes.gif] Whatcha throwing together now Mike? Todd |
ORIGINAL: wd40 I know now that 3 Tangos have went down. Mike Grant One thing I both liked and hated about the Tango was the snap rolls it could do. Nice, sharp, hard ones when you wanted it, along with the occasional unwanted one to go with a lapse in judgement. Gordon P.S. Mike - The BobCat XL I bought from you is still going strong, and still the prettiest jet I own - thanks! |
I am glad you like the Bobcat I think I will bulid a new Bobcat. The turbine was not hurt to bad I order parts and fixed it. I have test ran it and is running great now.
Gordon Could you send me some picture of my Bobcat I sold you I never got to take a picture of It and save it,and I wish I had that T-750 back I can't get one now.So i think I will get just order a WM 54 SS 18 pounder for a new Bobcat. Thanks Mike Grant |
1 Attachment(s)
The fuse came out pretty good there are a few pin holes but nothing glazing putty cant fix.....
1 Attachment(s)
Wings are primed now. I really wished the automotive paint place had the white fill primer but I settled for the gray. Looks like I may have this baby painted by the end of the week as long as the weather permits. So far the color scheam will be white nose fade to orange then to red and then blue at the back of the jet and I will flame the wings.
Edited for picture |
Sweet!! You did a great job on the resurrection Dave [8D]
Mike, It'll be the end of the year before you can get your hands on the new Wren Supersport 18 LB-thats the target frame I heard for introduction.I would love to have one myself for my YA F18 single, but I dont want to wait till the end of the year to get it done so I am gonna just slap a Wren54 in it .I will send it off to JD Ent. for some tweaking to get a little more out of it . Steve |
1
2
Thanks for all the complements. I guess the 1 , 2 is for mail verification, I know I have not got mail ever so hope you guys figure it out...
Dave |
Dave, did you tear the monokote off and glass the wings?
Sean, I ripped the monokote off and glass the wings and the horizontal stabilizer and all control surfaces.
Dave |
My tango is still in weighable condition so if you want I can weigh my peices and give you an idea of where you are at. I can weigh to the tenth of an ounce.
Sean |
Sean yea please weigh you Tango, that would be great. What will be in the air frame when you weigh it? I will weigh mine just before I paint and after I paint, as I am going to be using a 14 lb range turbine I am weight cautious. You like my AFP (Advanced Fabercation proccess) ;) glassed and primed in 1 day, one day I will have to post this proccess. Can you weight a wing for me?
Right wing with aileron and flap installed using aeropoxy on hinges is 11.4 ounces.
Sean, my right wing weighed right at 13 oz but thats with out hinges, still needs wet sanding so I can drop alittle more weight.
my booms will weigh alittle more because I filled this with expandable foam...
I think that's acceptable considering I just tried reproducing a popular arf wing recently that was built up and monokoted. I built it with foam and glassed the foam directly. The original wing was like 5.8 ounces and the new wing before glassing was 3.8 ounces. But after i glassed it it came out at 5.8 or 6 ounces before primer and paint! I threw it away as that's an abortion considering the full flying weight of this particular arf was 4.5 to 5 pounds. Can't beat monokote for weight, but your rebuild job to primer was only 1.5 ounces. That is awesome!!
FYI, I just weight the fuse it came out at 2lb 15.7 ounces. That's including the speed brake installed with servo and control rod. Also includes gear door nose cut out and hinged for gear door. Nothing else is installed or done on the fuse. Sean |
Sean, My fuse weighed right at 2lbs 2oz that is just the fuse no nose gear foarmers and no speed brake, and no Inlets.
Sean or Todd What are the legnth of the main oleos struts I haev a set of 3/8 struts and was wondering what the length is on your so see if mine are too short.
1 Attachment(s)
Well amost fully primed just need to finish the booms and wet sand the entire jet. Todd do you still have the original formers, I would like to use them as templets to build new ones? The one boom that was broken in two, I glassed backe together with 6 oz glass from the inside and used expandable foam to press the glass from the inside to the inside boom walls. On the out side I used 6 oz glass around the boom and sanded and filled, came out really good just need to finish them now.
| All times are GMT -8. The time now is 02:19 AM. |
