Regulated Propane Valve
I've got a question for all you guys out there and want some feed back on this. If someone were to build a truly "REGULATED" propane control valve that screws onto the propane throwaway canisters and deliver a constant pressure "ALL" the time. Would you guys buy'em or not? The setup would deliver the same pressure the second the valve is opened as it would after continual use. This would not be a Needle Valve setup that would give a punch of pressure when first opened - then settle down to a desired pressure after flow has commenced. Thanks for the feedback.
Allready have the design in use. Im just waiting on the parts from the various sources. It looks like less then $15
What would I need it for? I simply use a little cheapy needle type valve with my TJT 3000s, and they start every time just fine. Do some engines require a regulated flow?
Some of the smaller turbines could benefit
It seems that some of the smaller class of turbines might benefit from such a setup.
I agree: That Coleman stuff can be a pain to get at times.
(and $$$$) I posted a vapor chart a while back to show what pressures are being worked on with pure propane. |
Where can I get a coleman type valve here in Australia?. I have been to several camping shops and they all have the canisters but no valves. I thought of getting a small stove or lamp and modifying it to just use the valve. Any ideas??.
I have been starting my Wren with Butane, but I need to warm the canister slightly to get enough pressure. I can't do this at the field. |
Tom: A guy named D usher makes them. VERY good price. ill get you the url if I can find it. or another can chime im. Ken
Bkf,
Thanks, I would like to get one as soon as possible. Warming the butane bottle is a real pain. Regards Tom Watson Sydney Australia |
This isn't in reference to the Powermax
This is in reference to the straight propane ie: Bernzomatic propane, and yes, the Coleman propane - not the Powermax cartridges which are a different setup completely.
Re: This isn't in reference to the Powermax
Originally posted by gtmaxx This is in reference to the straight propane ie: Bernzomatic propane, and yes, the Coleman propane - not the Powermax cartridges which are a different setup completely. |
I solved my problem.!!! I got a coleman gas canister 70 butane/30 propane, and a small torch with the correct size fitting. I unscrewed the front of the torch and made a fitting to connect my gas pipe. Works perfectly and starts first time. The valve on the torch is easy to use.
Originally posted by TommyWatson I solved my problem.!!! I got a coleman gas canister 70 butane/30 propane, and a small torch with the correct size fitting. I unscrewed the front of the torch and made a fitting to connect my gas pipe. Works perfectly and starts first time. The valve on the torch is easy to use. Regards Tom Watson Sydney Australia |
Hey Mark,
what did you pay for your TJT 3000? Chris |
Originally posted by woketman What would I need it for? I simply use a little cheapy needle type valve with my TJT 3000s, and they start every time just fine. Do some engines require a regulated flow? |
1 Attachment(s)
BKF,
I found the torch in a camping shop in sydney. It is made in Italy by a company called Foker. part number 04001/A. it was A$20. I just unscrewed the front of the torch and screwed the tubing into the small threaded hole. Regards Tom Watson |
festo makes an "inline" regulator with a guage. It has 4mm fittings on the in and the output side. If anyone is interested, I will post the part #
Mickey |
1 Attachment(s)
Originally posted by TommyWatson BKF, I found the torch in a camping shop in sydney. It is made in Italy by a company called Foker. part number 04001/A. it was A$20. I just unscrewed the front of the torch and screwed the tubing into the small threaded hole. Regards Tom Watson |
Originally posted by jetdriver festo makes an "inline" regulator with a guage. It has 4mm fittings on the in and the output side. If anyone is interested, I will post the part # Mickey in one day :D |
Originally posted by bkf Even with the JC you fill the start tank up full and usually get a pop when starting. |
Yep
Lucky I guess;)? Fly that roo yet?
Originally posted by JohnVH Lucky I guess;)? Fly that roo yet? |
| All times are GMT -8. The time now is 10:03 PM. |
