RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   kero fuel pump (https://www.rcuniverse.com/forum/rc-jets-120/165404-kero-fuel-pump.html)
gmeister 06-17-2002 01:04 AM
kero fuel pump
Does anybody have a suggestion on what to use for a fuel pump to pump kero for filling.
patrnflyr 06-17-2002 01:32 AM
kero fuel pump
Jetcat's the only way to go! John
bcovish 06-17-2002 04:02 AM
pump
John's right. Also www.jerseymodeler.com sells the same pump made up with fuel container with built in battery pack and all the fittings.
Jackjet 06-17-2002 05:20 AM
Jet Fuel pump
Go to auto zone - kragen- cheif or even wall mart and buy yourself a electric gasoline fuel pump for $20.They work great.Why pay $100 or more for one ?
Jackjet
ageless 06-17-2002 05:30 AM
pump
Or check ebay for old gasoline pumps. I got mine there, and it works fine.
TO
LUV2FLYRC2 06-17-2002 05:44 AM
Jersey cans
Best kero fuel container and pump I have ever had. My jetcat loves it to. :) :) :) And they put your name and phone number on it also. Just use your radio charger to charge it. Thank's Jersey. :)
Joe McBride 06-17-2002 04:30 PM
Gas pump
I tried 2 different fuel pumps from kragen. The 2nd was rated at 90gal/hr. The problem is that when you pump through the small tubing we use they slow waayyy down. It took 20+ minutes to fuel my F18.
The Jetcat pump is awesome and it costs around $50. The F18 fuels in around 5 min.
Jackjet 06-17-2002 04:45 PM
Re: Gas pump
Just use big tubing and install a adapter fitting at the end of the hose.............
Javkjet
KXH121 06-17-2002 11:27 PM
Kero Pump 101
1 Attachment(s)
How about building your own? The one I built takes 3 minutes and 21 seconds to completely empty itself (2 1/2 gallons). It takes less than 2 minutes to fill my Bobcat XL with the associated pressure. You can substitute a blue 5 gal kero can if you want. Here is a list of parts.
Fuel Gan 2 1/2 gallons....$2.75 -----Walmart
Kavan Gas pump.............$21.95----Local Hobby Shop
On/Off switch..................$1.95------Radio Shack
Project Box for switch.....$1.79------Radio Shack
Wire and clips.................$2.50------Radio Shack
Scrap Aluminum and bolt.$1.00------Leftover stuff
Tubing.............................$2.50------Local Hobby Shop
Glass or Glow fuel fitting..$6.95-----Local Hobby Shop
Total $39.00 or so!!!
Saving $100.00 bucks doing it myself-------PRICELESS
Joe McBride 06-17-2002 11:48 PM
Kavan
The Kavan pumps were lasting me about 50 gallons and then crapping out. I suspected they were not meant to run continuous for 1/2 to 1 1/2 gallons.
It was the brushes that were going and I couldn't find a place to get replacements.
What are your experiences with the kavans?
DavidR 06-17-2002 11:53 PM
kero fuel pump
The Kavan's kept running for me but they leaked like hell een straight out of the box. THe newest Jersey modeler can is awesome. I have 2 of his cans and have had nothing but good luck from them. The one with the JetCat pump fills my Phantom in about 4 minutes.
David Reid
Gordon Mc 06-17-2002 11:55 PM
Re: Kavan
So far so good for me ... but one of my buddies who ran these pumps for his gasoline engines for years warned me to be careful which way up I mounted the pump. Supposedly these pumps are / were known for leaking after a while... and if you install the pump with the motor at the bottom this was VERY bad, because then the gas would leak down through the motor where it could start a fire. By mounting the pump the other way up, the above problem could be eliminated or at least mitigated.
I have not witnessed this problem first hand, but the guy who told me about it is very reliable, and not known for making things up ;-)
Gordon
KXH121 06-18-2002 12:36 AM
Substitutes?
Guys, use whatever pump you find rated for gasoline or kero for this simple project or pay the big bucks for the mail order one.
One word and one phrase: "Options and wallet depth".
