RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Startbox Display (https://www.rcuniverse.com/forum/rc-jets-120/185459-startbox-display.html)
DC1163 07-05-2002 04:44 PM
Startbox Display
Is there an adjustment for the startbox display? It can barely be seen.I have a 1000ES
Thanks David
Harley Condra 07-08-2002 02:04 AM
Start box display
I had the same problem once, and there is a simple fix.
If you open the startbox, you will find a small blue colored LCD Contrast potentiometer on one of the circuit boards. It is the only pot in the startbox.
Plug in the startbox, turn the transmitter and receiver on as if you were going to start the engine, and adjust the pot to get the desired display contrast/intensity.
Button the box back up, and you are all done.
This is covered in the owners manual, I believe.
Harley Condra
BVM REP
RAM REP
DC1163 07-08-2002 03:08 AM
start box
I know what you are talking about, I just did not want to touch anything until I was sure the pot was for the display,
Thanks Harley
rambat1 07-08-2002 03:17 AM
Startbox Display
Harley; Thanks for the help.
F9F Texan 07-09-2002 08:11 PM
Startbox Display
Thanks for the info, Harley. I thought the weak readout was just something I had to put up with. It seems to diminish as the receiver battery discharges, true?
Johnny
rambat1 07-10-2002 01:17 AM
Startbox Display
Johnny; You should not notice much difference in the display unless your battery is going down pretty fast. I recommend you check tour battery.
