RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Propane cylinder adaptor (https://www.rcuniverse.com/forum/rc-jets-120/2015128-propane-cylinder-adaptor.html)
sportflyer-RCU 07-22-2004 09:31 PM
Currently I am using a propane pressure regulator that fits the Coleman or Bernzomatic disposable propane cylinders. What kind of adaptors do I need to use this regulator with refillable propane cylinders? Tks
The Ghost 07-22-2004 09:44 PM
RE: Propane cylinder adaptor
1 Attachment(s)
Here's the setup I use. Very simple.
Cheers,
ajcoholic 07-22-2004 09:45 PM
You can buy these adapters at the camping stores, that allow the camp stoves that also use the disposable cylinders to use the larger (like the 20lb BBQ size) refilable ones.
How big a cylinder do you want to use?
AJC
sportflyer-RCU 07-22-2004 10:39 PM
I am thinking of using approx 4 lb cylinder. So I need an adaptor that fits the larger cylinder and with threads at other end to fit my pressure regulator . BTW are the pressures of the refillable cylinders same as the BBQ cylinders? Tks
The Ghost 07-22-2004 11:54 PM
Why so large? The cylinder in the photo is only 0.34kg more than enough for a days flying. I just refill at home from a 25 Lb bottle.
Cheers,
sportflyer-RCU 07-23-2004 10:14 AM
Looks like I need to buy a home refiller valve to reuse my disposable cylinders . There is remaining propane in each disposable cylinder when the pressure is too low and cannot be used for start up. I hate to end up collecting lots of partially used cylinders
abqflyer 07-24-2004 10:36 PM
On the subject of propane cylinders, does anyone know of a smaller propane cylinder than the typical Coleman or Bernzomatic? I want to put it onboard. I'd be happy with something that would only give me a couple of starts between refills.
Bob C.
