RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Ramtec fan mounts (https://www.rcuniverse.com/forum/rc-jets-120/2080169-ramtec-fan-mounts.html)
CARS II 08-12-2004 09:28 PM
Ramtec fan mounts
1 Attachment(s)
This is a question for those that have used Ramtec fans. How do I mount it to the fan rails? Am I missing something here? ( see pic. ). I got the screws and the washers but I think I need something more.
CARS II
CobraJet 08-12-2004 10:56 PM
RE: Ramtec fan mounts
It looks like you are missing the vibration dampers. Check with Top Gun Aircraft or [link=http://www.aeroloft.com/index.html]Aeroloft[/link] for starters.
F-16 Skywalker 08-13-2004 12:35 AM
i have the same fan,,well i call it a ramamax..lol... ramtech shroud with a dynamax inpeller..'
some use the vibration dampers and some dont, some swear by using them and other disagree but i havent used them and havent had a problem,,(alway check you nuts and bolts at preflight) but use at your prefference
best regards: Chuck
siclick33 08-13-2004 04:17 AM
As Cobra Jet says, there should be some rubber grommet vibration dampers.
I would use them as the fan does spin pretty fast and it is very difficult to get them 100% balanced. Also it is a pain without them as the holes are too big (as you have probably found).
JimBrown 08-13-2004 07:40 AM
1 Attachment(s)
Here's a couple of pics that show the bits you're missing. Hope this helps.
...jim
CARS II 08-13-2004 04:02 PM
Chuck, Jimand, siclick23+10=33.
Thank you all for the information, I'm ordering the parts next week from Aeroloft.
CARS II
