RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Byron starter probe HELP!! (https://www.rcuniverse.com/forum/rc-jets-120/2084260-byron-starter-probe-help.html)
VA 08-14-2004 09:15 AM
Greetings Jet guys. I have a question about my Byron fan starting probe while trying to start my F 16. :( The threads inside the probe are some what worn and I decided to drill a hole in the base of the the starter probe shaft and drill a hole on the base of the starter probe and use a small hardened bolt or cotter-pin to keep them from slipping. So far this works ok but can be prone to alot of slop.[:@] Any pictures or advice or even an alternate way to start these fans without using that long-ass abomination??[:'(]
Thanks for any help or criticism.
skyhawknut 08-14-2004 11:54 AM
RE: Byron starter probe HELP!!
All fans need a wand of some sort to start them. (unless you have something like a Lear or A-10)
I keep the cup and rubber cone on my starter and push the Byron wnd into it. Works good and I've had no slipping problems since I started flying jets (about 8 years).
jetflyer 08-14-2004 09:21 PM
1 Attachment(s)
Yeah, you need to get the cone that will allow the starter wand to be pushed into the rubber cone. See the pictures below.
JR Gautreaux
VA 08-15-2004 10:29 AM
I use a rubber insert for my heli ike that and I had success. Thats a good idea. It sshould work as good for the long starting probe. Ill have to try that. I appreciate the help!!!;)
