Roo II Elevons Binding - Fix ?
The top side of the Elevons on my Roo II are hitting/binding (at times) with the top of the wing skin/lip. I heard this is a fairly common issue and I heard the fix was to use some clear tape on the top side of the Elevon .... so it will slide easier under the wing skin/lip. Wondering what is the best method for this fix. I am also concerned that that the tape may come off in flight .... and the Elevons will again bind. Thanks. Bob
RE: Roo II Elevons Binding - Fix ?
I took some 200 grit sand paper and releived the gap just a bit untill they worked smoothly. Be careful that you keep the hing line straight though or it will look bad. Russ
Ditto on opening the gap with sandpaper.
I used a clear hinging tape, I think it was for glider hinges, it is more durable than sellotape, perfect no problems at over 200mph, Im pretty sure sellotape would be ok too. I tried the sanding method but the tape is so much easier
Mark Diggle |
You can also heat it a bit and slip a credit card or something in there and lift it clear. It will cool to form.
the tape fix works perfectly and lasts very well...simple and quick and works everytime!
careful if you are going to try heating it ?? the upper skin can delaminate from the foam ! and the foam can detatch from the wood !!!
Wojtek |
[sm=confused.gif]Any pictures of how the hinge tape is used? Can't get the idea straight in my mind (THAT is nothing new![sm=spinnyeyes.gif])
1 Attachment(s)
here's a picture of the tape i used.
you let one side of the tape touch the elevon horn and the rest just slips under the uperskin of the trailing edge. |
[sm=thumbup.gif]Thanks for the picture!!!
Did you also sand the hinge line to open it up a bit before you put on the tape? |
ORIGINAL: seanreit You can also heat it a bit and slip a credit card or something in there and lift it clear. It will cool to form. |
1 Attachment(s)
I bought some special tape from graupner, that is only sticky on one half. It is also quite firm compared to normal tape.
I think it is used for gap sealing sail plane wings...... works great on the euro! |
:DMore Great Pictures!!!
Thanks very much guys--really a BIG HELP. |
ORIGINAL: RAMFlyer [sm=thumbup.gif]Thanks for the picture!!! Did you also sand the hinge line to open it up a bit before you put on the tape? its in front of the control horn |
| All times are GMT -8. The time now is 07:33 AM. |
