Help Setting up Saddle Tanks and Hopper
Hi Guys,
I'd like to know the right way to set up twin saddle tanks and a hopper tank (3rd) tank in my ducted fan. Do I "T" the twin tanks into the hopper, or run them one after the other in series?????? Thanks Ernie |
RE: Help Setting up Saddle Tanks and Hopper
Ernie,
I have always plumbed the saddle tanks in parallel to feed the hopper tank, and it has never failed for me. Jeff |
Ernie
Have both the mains feeding feeding the center and use a T with safety wire it on. Best Of Luck |
Ok, just to make sure I'm on the same page as you guys, your running both main tank feeds "T'd" into the hopper's vent, the hopper pickup to the carb. Both main tank vents "T" off the pipe pressure.
Is this the setup your running? Thanks Ernie |
1 Attachment(s)
ORIGINAL: Red7fifty Ok, just to make sure I'm on the same page as you guys, your running both main tank feeds "T'd" into the hopper's vent, the hopper pickup to the carb. Both main tank vents "T" off the pipe pressure. Is this the setup your running? Thanks Ernie |
If you are going to use the parallel system, make sure the lines coming from each tank to the T's are the same length.
1 Attachment(s)
Ernie,
Here's the BVM instructions. As bcovish said, keep the fuel and pressure lines to the saddle tanks the same length. After I plumb mine I usually fill and drain them several times using my electric fuel pump to make sure the saddles drain at the same rate. If they don't, shorten the fuel line to the tank that takes longest to drain a little bit at a time untill they drain at the same rate. Joe |
I have found the Y- fittings seem to flow better than the T-fittings .
Charlie |
Thank you Guys!!!!
Ernie |
| All times are GMT -8. The time now is 02:09 PM. |
