FUEL PUMP HELP
HI ALL,
Im looking for a replacement fuel pump for my turbine stuff mine stoped working every thing i find is for nitro not Jet/gas. For any help thanks you AL (SIXSHOOTER)[8D] |
RE: FUEL PUMP HELP
A few options [link=http://www.rcuniverse.com/forum/I_gotta_know%21%21/m_2554658/tm.htm]HERE[/link]
RE: FUEL PUMP HELP
Sig makes one called the " Gas Passer ". $32.00
RE: FUEL PUMP HELP
CERMARK - Great Price and Performs perfectly...
RE: FUEL PUMP HELP
There are some great gas pump solutions, but at $200 bucks thats too much!
I made my own solution with a Sig Gas Passer, (8) 2300 mah NiMh cells from Long's. I also bought a small project box to mount the spring-loaded switch (from Radio Shack) (the spring turns it off, so it cannot accidentally spill gas, and the box is so the spark from the switch happens in the box and cannot ignite the fumes). So far I have pumped about 10 gal of gasoline through it, and I like it. |
RE: FUEL PUMP HELP
McMaster-Carr has the right pump for our needs.
Catalog # 8220K32 goes for $46.97 ea. This is a very commonly used pump for RC jet fueling. www.mcmaster.com Harley Condra BVM REP Team JetCat |
RE: FUEL PUMP HELP
and the box is so the spark from the switch happens in the box and cannot ignite the fumes). |
| All times are GMT -8. The time now is 04:38 AM. |
