RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Do I need a heat Shield for this installation? (https://www.rcuniverse.com/forum/rc-jets-120/2717908-do-i-need-heat-shield-installation.html)
Ragz 03-02-2005 09:50 AM
1 Attachment(s)
This is a DRACO trainer jet. The engine exhaust seems extremely close to the wood areas. Do I need heat shield here? Moreover, what can be used as a heat shield instead of BVM heat shield. I live in India and getting the BVM product will take some time. I would like to use a substitute for the moment, if any.
I-NAV 03-02-2005 10:10 AM
RE: Do I need a heat Shield for this installation?
Anurag,
You could make a heat shield from .0008 inch (very thin) aluminium. As long as your getting some airflow over the alu you will be fine.
seanreit 03-02-2005 10:33 AM
Ya, aluminum tape comes to mind. Also, wood is a very poor conductor of heat, and you are far below the temperature for it to combust via temperature. I think you'll be fine, it will get hot, but not "too" hot. But if I was in a pinch, aluminum tape would be my choice.
Ragz 03-02-2005 10:48 AM
thank you, i will see what can be done.
