RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Pylon Attachments (https://www.rcuniverse.com/forum/rc-jets-120/2732800-pylon-attachments.html)
JSF-TC 03-06-2005 10:41 AM
Pylon Attachments
How do you guys make wing pylon attachments on foam wings?
Do you set a ply plate into the lower surface of the wing with a captive nut on the 'inside' surface, and have the nut trapped for ever, or do you use a fancier solution where you could remove the plate to replace the nut if you strip the threads?
Paul
Topgun2mo 03-06-2005 11:38 AM
RE: Pylon Attachments
I have used the BVM threaded inserts meant to be glued into the wing. Simply drill a hole and glue in. Go to BVM's website http://bvmjets.com/ and then go to accessories, then bomb drop. There you will see a sketch showing the inserts I am talking about. I doubt that you will strip these.
Vincent 03-06-2005 01:32 PM
I have used a wood dowel cut to size and glued in the foam wing flush with the wood sheeting. You can secure the pylon with a simple wood screw.
V..
