ultra precision valves
Are these things worth a crap? I spent hours trying to get the timing correct with no luck.
I'll adjust the one that needs to speed up or slow down, and it affects something else that then needs to be adjusted. I'll stick to robart valves and an electronics to do my timing. I would have been done setting up the gear and doors by now. The couple of guys that have used them around here. Have had the same trouble. I've heard that they work great also. whats the deal? |
RE: ultra precision valves
I love em!
I've had good luck with them so far. I can tell you that the needle valves tend to trap dirt. On the first one I had for my Panther, the gear was moving VERY slowly. I kept backing out the needle valve until it finally came out. It poped out with the air pressure and a little black ball of crud came out behind it - problem solved. That valve has worked great since. You might try taking the needle valves out of yours and seeing if there is any dirt in there that could make it hard to adjust.
I have a UP-2 and UP-3 on my Euro and they have worked fine so far. Bob |
Just installed some valves which are6 years old in my Hawk and Eurosport, they work a dream just as another does in my Sabre.
Regards, David gladwin. |
Scott,
Give me a call and I'll see if I can help you resolve the problems.... UP Valves have always works perfectly for me, prefer them over the electronic units. I'm sure I can get your problems worked out... Todd |
Works fine, if you have good cylinders. If cylinder leaks then the valve fails.
Darryl Usher |
the up guys are great
and dirt is always the problem....a words of note 1) dont get to crasy with original lubeing..if you do this can cause it 2) lubeing lasts for years not 1 or 2 but several 3) snug tight firm the locking nut dont kill it 4) if you ever nick one they will send you some...free....send them a sase and a note...find their address on the net in canada...dont replace with standard replacement ones...as their`s are fatter than stock ones found in those mulitple size replacement boxes 5) they are great guys just email them and they help if needed hope this helps gregg |
| All times are GMT -8. The time now is 03:52 PM. |
