A-10X Preview
1 Attachment(s)
Thought you guys might like to see a few pics of the new A-10X. I am currently building one, powered by an Artes Bee, to test flight performance and compile the manual. So far, I am quite impressed with the quality. With the exception of some poor glue joints to the fuse formers (which will be corrected on production), the kit is very well made and should be an excellent grass field capable, trainer type aircraft (or, every day beater ;)). Airframe consits of a fiberglass fuse and booms, built-up wings, center section and stab. Assembly is minimal, really just a matter gear, electronics and engine installation... The kit is designed around the 54 class engines, it is not possible to fit a larger can (ie: KJ66 size) in the mounts. The A-10X will be available in three color schemes and will also be offered as a combo package including retracts, wheels, air support, fuel tank ect...We are expecting delivery of the A-10X in early August.
BTW, not seen in these images but included is a belly pan which has the wheel wells molded into it.... Todd |
RE: A-10X Preview
Looks nice Todd and hope that all goes well for you. In the photos the seam lines are pretty apparent and the Monokote work on the underside of the wing needs some attention too.. But it's just me being picky :). What retracts is the bird built for?
Cheers, |
RE: A-10X Preview
Tim,
I'll assume you mean the fuse seam lines (painted in the mold fuse)? No seams seen in the covering as they are done at the leading/trailing edge.... As for the loose covering, anyone who lives in florida knows this is typical for an out of the box ARF, especially in dark colors... The heat tends to sag the covering until it has been heated and rubbed down good. Even then, you have to keep shrinking it back up during our hot summer days (our flying season is oct thru may ;)). Retracts... they are also supplied by RCARF and I have no yet received a set. I have ordered a set of Robarts new spring-air style gear to test out in this plane along with as set of the robart 550s to see which will be the best for this application. Will report on their performance as well if you are curious... Todd |
RE: A-10X Preview
Tood,
You see what I mean? [sm=thumbup.gif] Miguel |
RE: A-10X Preview
Yep I was speaking of the seam lines on the fuselage. But it still looks great and understand about the Monokote. I live in Kentucky and experience the same problem here with the sagging. I'm just being a stinker held hostage at the office and waiting for the weekend to get some flying in. Yes I am interested and looking forward to your report.
Cheers, |
RE: A-10X Preview
Hi Tod,
You will love this plane. Let me know if you need any tips. Regards |
RE: A-10X Preview
Hi MNModels,
I saw you posted some photos on #1 test flew in SA in another thread. Perhaps, you can share the #1 throws setup and CG with us B Regards Albert |
RE: A-10X Preview
Hi Albert,
The CG is 115mm from the leading edge of wing. Aileron : 30mm up and down Elevator: 25mm up and down Flaps : 60mm down Rudder : 25mm left and right. I fly with JR10X radio and have the 3 mode setup for flight. After takeoff i switch over and travel is reduced. When i fly from short field (100m) i use full flaps for landings. No bad tendancy. Just remember not to get under the power curve. The A10X lands very slowly. With a slight breeze you can land her in 50m with no brakes. Let me know if you need more info. I will post some more pictures as soon as i got the time.. Regards |
RE: A-10X Preview
Hi Morne,
Thanks on the first hand infor. Hopefully Todd has some new progress to share again! B Regards Albert |
RE: A-10X Preview
Todd,
Have you gotten YOUR A10-X airborne yet? Interested to know how it performs. |
RE: A-10X Preview
1 Attachment(s)
Steve,
Maiden was intended to be this past weekend but was scrubbed to weather (forcast was rain, rain, rain... it didnt :eek:)... Planned now for sat or sun. Will provide post flight report and video... Todd BTW... Big thanks to Phil Nuckles for doing most of the assembly! |
RE: A-10X Preview
Hi Todd,
Any list of servos and leads extension used? B Regards |
RE: A-10X Preview
Interesting. What is the length, span, wing area and approximate dry weight?
RE: A-10X Preview
Length: 65"
Wingspan: 67" Weight: 12-17Lb Power: 9~18Lb thrust I have not calculated the wing area, I'll try and get it measured up for you although it is fairly high. Todd |
RE: A-10X Preview
Todd,
Might be fun to have an 80% version for the MW44. Is there a plan set with cross sections? |
RE: A-10X Preview
No plan set that I am aware of, would not be a difficult plane to scratch up though. Fairly simple design.
;) Todd |
RE: A-10X Preview
Any luck with the maiden Todd?? I've made it to Killeen but no address as of yet. They say that my house will now be ready on the 1st of Sep so Im living out of a hotel room.
Luis |
RE: A-10X Preview
*bump
RE: A-10X Preview
Luis, I spoke to Todd today, the airplane is ready, just a matter of finding the time. You down in Killeen? You going to Lubbock or Waco rallies?
RE: A-10X Preview
Hiya Sean.. made it to Killeen last Friday. The house wont be done till 1 Sep and I hope to make it to Waco. Sounds like its gonna be alot of fun. I hope to have the A-10x ready for flight testing and maybe signoff by then...we'll see. Im not going to rush it. Awaiting a flight report for the A-10 from Todd along with an electrics reccomendation(sp). :)
Luis |
RE: A-10X Preview
Look forward to seeing you again. We'll polish off a little more alcohol and I'll take some of your cash in Hold 'em.
See you then. |
RE: A-10X Preview
I know guys, really sorry I have not been able to report on the A-10X. Intended flight dates have been scratched due to weather or priorities [:o].... Time has been extremely slim for me lately and commiting a full day ( almost two hour travel to flying field) for the A-10x has been difficult. I am expecting to get out sunday, weather permitting. Hopefully i'll have all the info for you soon. Need to find a video camera I can borrow, mine crapped out on me [&o] Worst case.... i'll use my video function on my digital camera [:'(] Stay tuned... Todd |
RE: A-10X Preview
1 Attachment(s)
Well, Weather has postponed the maiden on the A-10X again [:'(]
I know there are a bunch of you waiting for this info, rescheduled for this weekend...Sat or Sun, whatever works. Several have asked for more images of the plane, Detail shots.... so, while your waiting for flight reports, I thought I would throw these up... Todd |
RE: A-10X Preview
1 Attachment(s)
Only "Mods" made was addition of the "FOD" screen to the intakes and the systems tray for a clean install. In order to make the tray easy to install/remove, I split the tray down the middle and hinged it with CA hinges. This allows the tray to fold as it is installed.
Retracts used where Robart 550 series with 7/16 struts since I was not able to get the "Combo Package" at the time of build. I also used a Dubro 50oz tank, the included fiberglass tank was also not ready at time of delivery. |
RE: A-10X Preview
As you can see, the linkage is way overkill for this plane (servos too) but I plan to wring this thing out to the extremes... Looking to get an idea of this plane full capabilities. If I cant break it, no one will :D Lets hope the rain holds out this weekend!
Todd |
RE: A-10X Preview
Todd, great pics. What electrics did you use. I want to start searching for stuff now so that I wont be ordering while im building. Also, what type linkages did the kit come with and what did you use in its place if anything. Thanks!!
Luis |
RE: A-10X Preview
Hey Todd, I'm just catching up, loved the video, can't wait to see it in person some day. Not sure what current events mean for Jet Travels later this year, but if FIJR can be made, it will.
Always a pleasure seeing something work as intended and designed. Sean |
| All times are GMT -8. The time now is 11:23 PM. |
