DF setup, help
Hey people, I bought a regal eagle off a fellow and I've about got it ready to go but I don't understand how the fuel plumbing works. It has the usual three hoses from the fuel tank. One to the carb and a second to fuel (both with clunks and in the correct position in the tank). Then there's the third hose which would usually goto the muffler but in this case there is no nub for it. I don't get how I'm supposed to set this up. There is a place next to the fan where it looks like the line should go but I can't figure out why you would have it there.
Help out a wannabe jet guy will ya, I'm desperate to get flyin. |
RE: DF setup, help
DF can use 'fan' pressure or pipe pressure.
If you have the fan pressure fitting I would use that. The inlet for this fitting should be behind the fan, pointing towards the front of the model (i.e. into the fan airflow). The two methods achieve the same aim of pressurising the fuel system. |
RE: DF setup, help
Right on, thanks man. Ya learn something every day eh!
RE: DF setup, help
1 Attachment(s)
I have a new in the bag pressure fitting for sale if you need one or two.
Not the best pic. but what can I say. CARS II |
RE: DF setup, help
I actually have on in it already. Ya see, once siclick33 edumacated me (hick), all seems to be well. I went outside, fueled her up and dam does that thing scream. :D
Taxied around a bit and all looks well, I'll be doing the maiden tomorrow. Thanks for the offer. |
| All times are GMT -8. The time now is 12:37 PM. |
