RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Ok, Robart gear users, question (https://www.rcuniverse.com/forum/rc-jets-120/3363337-ok-robart-gear-users-question.html)
seanreit 09-15-2005 10:56 PM
1 Attachment(s)
Robart 630 nose gear and strut, the centering wire is too short that came with it, what are some normal solutions?
Lt. Dan 09-15-2005 11:07 PM
RE: Ok, Robart gear users, question
Shape a new one with piano wire? http://www.kc-10.net/forum/images/smilies/whoknows.gif
rcav8tr 09-15-2005 11:27 PM
Hey Sean
Can you post a clearer picture. One focused on the strut and not the wall behind it? ;)
Ed
K1 Burner 09-15-2005 11:39 PM
don't call Robart. 6 weeks ago I was told my order was being shipped that day. Still do not have it as now they are again making the parts. Must have sold the first ones to GP.
Gerald Rutten 09-16-2005 04:29 AM
As an alternative.........ask someone in your vicinity who has built an Avonds F16. This part has no use on his altered 90° nose gear twist system and is set asside. (From looking at your pic. mine was indeed longer.)
Could sent you mine for free, would be expensive little wire though as it has to be shipped from Europe to you......:eek:
Regards,
Gerald
pilott34 09-16-2005 07:02 AM
ORIGINAL: K1 Burner
Ive had nothing but the opposite experience. I broke the nipple off of one of my air cylinders in a 630 model. Robart offered to fix it for me. I told them that I was flying the following weekend so they overnighted me a brand new cylinder. Thats the only dealings Ive had directly with them, but my experience was good.
Mike
lov2flyrc 09-16-2005 07:25 AM
ORIGINAL: seanreit
Sean, I have a replacement wire if you need it.
Gordon Mc 09-16-2005 08:34 AM
Is the wire definitely all the way down, under the retaining screw at the top ?
A temporary and non-perfect possibility ... if you bend both legs of the wire inwards sliightly, then they will effectively seem longer (Basic trig - assuming we measure the angle at the top - reduce theta, reduce the opposite, keep the hypoteneuse constant, then the adjacent must become longer).
Gordon
seanreit 09-16-2005 08:51 AM
Hey Gord, thanks for the options, all of which had been exhausted. I'm considering just tapping the screw a little lower, I hate drilling and tapping aluminum. Robart used to get everything Right, but this is just dumb.
Oh well, thanks for all the help options guys,
Sean
Gordon Mc 09-16-2005 09:54 AM
ORIGINAL: seanreit
OK - another temporary possibility if Todd can't get you the replacement wire as quick as you would like... how much clearance is there for the "arms" when the gear is in it's retracted position ? What I'm thinking of, is that if you can't get the wire longer, can you get the arms to be "higher" by e.g. C.A-ing a thin plywood tab on top of the arms ? With the right CA it should hold well enough until you get the replacement wire, and CA solvent can be used to clean the arms up afterwards when you remove the tabs.
Another "imperfect" and inelegant solution to be sure, but it might get you going in the short term. If you do try this though, please test that you have proper adhesion on the tabs, as you wouldn't want to lose ground steering due to an insufficient bond.
Along similar lines - could you "extend" the spring very slightly by crimping / soldering / whatever a thin brass tube over the ends of the wire ?
Gordon
seanreit 09-16-2005 09:58 AM
You the man Gordon, didn't think about soldering brass that would work, but would be fugly.
I'm in no hurry at all, I just started on the airplane this is going into, and wanted to set it on gear, but I'll wait.
Todd, I'm gonna put an order in on your site, just throw the right retainer in there, this is the nose gear retract I bought from you in March or April. I got a second hand ROO that I'm putting together for a buddy of mine, and came across this.
seanreit 09-16-2005 09:59 AM
Todd, FYI, the length on this wire is 1.5 inches, needs to be more than that even if it's just an 1/8 of an inch.
seanreit 09-16-2005 10:09 AM
1 Attachment(s)
Not that I have a problem with FUGLY ;)
ghost_rider 09-16-2005 10:39 AM
Sean
Your problem is that the strut does not recess into the trunion as deep as it should.
Just bevel the edge of the top of the strut and recess it as deep as you could get it and you will be ok. The rotating part of the strut that tightens into the trunion should be flush with the opening and that is not the case in your picture
seanreit 09-16-2005 10:47 AM
Ben, that helped, and got me close enough. Thanks.
