RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Amount of fuel enough??? (https://www.rcuniverse.com/forum/rc-jets-120/3363572-amount-fuel-enough.html)
speedaholic 09-16-2005 01:05 AM
1 Attachment(s)
I have a cjm f-4 that i installed the bvm f-4 fuel tanks setup, i believe it to be about 135oz of fuel or just over a gallon, i have a artes rhino installed, is this going to be enough fuel or should i or can i install 2 more small tanks behind the mains in line, will this put to much resistance for the pump, it has right now to mains teed to the heaedr which feeds the uat. what do you guys think, aould it be a good idea to add two more tanks????
I-NAV 09-16-2005 02:42 AM
RE: Amount of fuel enough???
You've got about eight minutes of flying time at full throttle. If you think 6 mins is enough (plus 2 min reserve) then you're fine.
I wouldn't worry about the pump. My P-120 is pulling 5 tanks with no problems.
Tom Antlfinger 09-16-2005 08:59 AM
After some 130 or so flights on my KingCat with a Rhino on it, I find that it burns about 14 oz/minute per flight with fairly agressive throttle usage........Rhinos do suck the JetA at full throttle, but they have lots of power at 1/2-3/4 throttle which cuts overall consumption down to reasonable levels.....I routinely set my timer for 9 minutes at the start of takeoff and had enough left for at least 2 go-arounds if necessary.....the KC carries 160 oz total fuel.....so I would deduct at least 1 minute, maybe even 1 1/2 minutes for 135 oz.....
Tom
speedaholic 09-16-2005 10:24 AM
ok, if I add the two smaller tanks behind the mains would i just balance full of fuel since they would be behind the cg????
Dave Presta 09-16-2005 01:17 PM
Will you be Test flying this plane yourself at Fresno? If so, what day?
speedaholic 09-16-2005 03:51 PM
i will have it there but i think i am going to wait to test fly at crows just to have a little more space, i will need some help for sure, i might get a nervous tick in my thumb...:D. i want everyone to check it out at fresno and i can get some tips from the pro's. I was thinking if balanced empty my header tank and uat are in front of cg so when full it will be nose heavy on takeoff, if i add the 2 extra tanks behind the mains it may make the balance perfect for takeoff and get slightly nose heavy after fuel is burned off. just a thought
