Df engine question
Hi everyone
Has anyone tried the .40 GRRT PYLON engine from MVVS for ducted fan use? Its specs look close and it not too expensive. see link for the engine http://morrishobbies.com/product_inf...96cd95af4c5906 thanks Kev |
RE: Df engine question
Kev,
I don't think you will get the RPM you need for a fan out of this engine. Plus it is wider than most fan mounts. The GRRT works well with props though. Mark |
if you can fit one in a kress 740 fan , www.kress-jets.com , you may be able to fly small ducted fan jets, like the F-86 from electric jet factory( formely HOB ) or the f-4 FROM JD enterprise ; i dont think that you could fly regular .45 size jets ( like jet hangar ) with that combination Pecojets |
| All times are GMT -8. The time now is 11:15 AM. |
