RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Skymaster F-15c (https://www.rcuniverse.com/forum/rc-jets-120/3676664-skymaster-f-15c.html)
2605 12-21-2005 07:23 AM
Skymaster F-15c
1 Attachment(s)
Here is my new jet from Skymaster F-15c.
more pictures will come as i start to assemble the jet.
Stig Andersen 12-22-2005 06:27 AM
RE: Skymaster F-15c
Congratulations Morten. ;)
What engine are you going to power it with?
2605 12-22-2005 07:09 PM
RE: Skymaster F-15c
Hi Stig simjet 2300 it works;)
Stig Andersen 12-23-2005 03:07 AM
RE: Skymaster F-15c
Well, as you know, I ordered a SM F-15 from Al's Hobbies as well. Maybe Santa will put it under the tree;)
I will power mine by the Simjet Sonic 120 which is practically the same engine as yours, only homebuild.
turbinepeter 12-23-2005 12:53 PM
RE: Skymaster F-15c
1 Attachment(s)
Great looking Kit there buddy.
I too am hoping Father Xmas leaves me my F15.
well it was delivered the other day, but the wife won,t let me play with it until Xmas day.
A large hole in the box, but the contents survived!!!
cant wait to get it all out!!!
2605 12-23-2005 05:52 PM
RE: Skymaster F-15c
Hej there looks like my box but the kit survied[8D]
2605 12-26-2005 05:25 PM
RE: Skymaster F-15c
Anybody could tell me if sm struts for F-15 is to soft to use on grassfield.
AirPac Models 12-26-2005 11:40 PM
RE: Skymaster F-15c
1 Attachment(s)
Should be no problem. We have a lot of customers use on grassfield.
Stig Andersen 12-27-2005 03:31 AM
RE: Skymaster F-15c
1 Attachment(s)
Morten.
I'm using the same struts on my Skymaster F-22 and they hold up pretty good. Even on the rought grass field at our club. ;) But I do recommend that you use soft wheels (I use Robarts) as they will take some of the beating from the rough field.
Stig Andersen 01-10-2006 04:21 PM
RE: Skymaster F-15c
1 Attachment(s)
I received my SM F-15 ARF from Al's Hobbies today. It looks really good, and I'm sure I can finish the model in time before traveling to Florida Jets in March. All the parts go together real well. Only thing I could find is a slight mis-alignment of the canopy hook, but that can easily be fixed.
Daughter Johanne shows her daddy's new toy.
2605 01-19-2006 04:56 PM
RE: Skymaster F-15c
1 Attachment(s)
would like to add scale light on my F-15 nav light roatning beacon.
anybody could tell where to place it.
AirPac Models 01-19-2006 10:02 PM
RE: Skymaster F-15c
1 Attachment(s)
Some pictures of the F-15 Bicentennial color scheme for your reference
Stig Andersen 01-20-2006 04:26 AM
RE: Skymaster F-15c
1 Attachment(s)
I added the decals to my SM F-15 yesterday. Here are some pics.
turbinepeter 01-21-2006 03:26 AM
RE: Skymaster F-15c
1 Attachment(s)
Hello you F15 Owners
I have just taken delivery of the SM Tailpipe for the F15. And I noticed that the Bellmouth to the pipe is loose!!
Should this be spot welded in place or do I need to do something else to it??
I would have thought that this should not be loose.
Could someone shed some light on this.
Many thanks
Peter G
Stig Andersen 01-21-2006 04:14 AM
RE: Skymaster F-15c
1 Attachment(s)
Hello Peter.
I drilled 3 holes though the belmouth and pipe, and tightened the belmouth with some 2,5 mm screws. I let some cyano run around the edge.
AirPac Models 01-21-2006 04:42 AM
RE: Skymaster F-15c
Hi Peter.
As Stig said, 2 or 3 screws are required to attach the bellmouth
Charlie H. 01-21-2006 10:50 AM
RE: Skymaster F-15c
I've used 1/8 " aluminum pop-rivets , don't have to worry about the screws coming loose .
Charlie
Stig Andersen 01-22-2006 08:26 AM
RE: Skymaster F-15c
1 Attachment(s)
I did some basic work on the cockpit today.
#1: The parts supplied for the cockpit.
#2: The two seats were cut to lean a little backwards. The rear seat needs to be cut approx. 10 mm (3/8") shorter than the front seat in order not to go against the hood. I scratched off the paint of the cockpit floor where the seats were to be glued on.
#3: I mixed up some 30 minute epoxy with some carbon to make a black glue that will be less visible.
#4: I glued the seats to the cockpit floor using some scrap balsa as aid for the seats. The balsa was held on to the seats with dobble sided tape. The whole setup was taped down while the epoxy was curing.
#5,6&7: The finished cockpit ready for some scale detailing. I might just fit a pilot dummy to the front seat, and leave it at that. After all, it's an ARF..;)
Stig Andersen 01-22-2006 08:30 AM
RE: Skymaster F-15c
I don't know what happend with those pictures, but I uploaded them the way I usually do.......
Sorry if the pictures are a bit "shaken". I'm not tellin' why[sm=spinnyeyes.gif]
thomas_ericsson 01-22-2006 08:48 AM
RE: Skymaster F-15c
1 Attachment(s)
i just wanted to share some photos on my SM F15 [8D] :)
thomas_ericsson 01-22-2006 08:51 AM
RE: Skymaster F-15c
1 Attachment(s)
one more :D
turbinepeter 01-22-2006 11:01 AM
RE: Skymaster F-15c
Thomas
Great looking F15. Can you tell me what you highlighted the panel lines with. I like the idea of doing that, but wasnt sure what to use.
Regards
Peter G
Stig Andersen 02-04-2006 04:38 PM
RE: Skymaster F-15c
1 Attachment(s)
Morten and I finally got the servoes for our SM F-15's. On the rudder and anileron we're using the Graupner/JR DS3328 with 4 kg torque and 9 kg holding power. On the flaps we're trying the new DS8081 with carbon gear, 5,5 kg torque and 12 kg holding power.[8D]
2605 02-20-2006 12:37 PM
RE: Skymaster F-15c
1 Attachment(s)
A few pictures
Stig Andersen 02-20-2006 05:00 PM
RE: Skymaster F-15c
1 Attachment(s)
Hey, hey. Hold it now, Morten. Are you going to maiden your F-15 before me????;)
I have installed the servoes and the pipe is the one from my F-22, that has been retrofittet into the F-15. Not a perfect match, but it is OK.
