RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   making your own servo ends (https://www.rcuniverse.com/forum/rc-jets-120/3787990-making-your-own-servo-ends.html)
trioval00 01-17-2006 05:12 PM
I just noticed a web site here in RCU, where they sell all the parts to make your own servo ends.
My question is, How many of you make youw own extensions/servo ends for the jets?
rhklenke 01-17-2006 05:41 PM
RE: making your own servo ends
Mark,
I know some guys I work with in the UAV area bought the stuff and tried it. They're no dummies, but they said that the reliability of their in-house ends weren't as good as the commercial ones, so they stopped doing it and just make custom lengths by splicing wires - which is what I do...
Bob
seanreit 01-17-2006 05:58 PM
Just order from Electrodynam.com and be done with it, I spent a hundred bucks on custom ends started making them and said screw that. Went and ordered the good stuff from Electrodynamics.
DrScoles 01-17-2006 06:19 PM
I bought all the stuff to make my own ends.... I find its easier and more reliable to just cut and solder in an extension of HD wire... Crimping the gold connector properly and getting it all the way into the plug is a PIA...
Still do it for my micro helicopters, where the heat shrink from the solder job would be too stiff...but on a long extension... I say solder it...
Mike
EASYTIGER 01-17-2006 07:08 PM
I also spent bucks for the whole Custom Electronics connector kit, the crimping tool, plenty of supplies, all that stuff. Sits in a drawer gather ing dust. Not only is it more time consuming to make your own connectors, they are just incredibly unreliable...dangerously so. I won't use the stuff. Much easier and safer to solder in an extension. Like all the others are saying.
mr_matt 01-17-2006 08:26 PM
I make all of my own. They work fine, just have to follow the directions. In my experience they are not really cheaper then commercial, but you get to make the length exact.
KevinBarr 01-18-2006 06:07 PM
1 Attachment(s)
Folks,
Thought I would share some connectors I have used for a number of years and they work AWESOME. AMP makes a line of connectors called MTE. They come in different pin counts. I use the 3-pin version (obviously).
The nice thing about the connectors is they have a locking tab on them, so you don't need to use any type of extra clamp to make sure they don't pull free. They also are the EXACT same size as the original Servo Ends (see pics)
The connectors come in a variety of !QUOT!crimp!QUOT! styles. I use both the Speed Crimp style, shown here, and the style where you crimp each pin individually.
I show in the pics the crimper you use. It works really slick as you don't have to strip the wire, just insert in into the connector and squeeze.
The single crimp style requires you to strip the wire.
Another good thing is the connectors also come without the locking tab so it will plug right into your receiver as well.
Just my thoughts, hope it helps.
Kevin
seanreit 01-18-2006 06:13 PM
Kevin, can you post specific website and specific part numbers and description of each part number so that I can order some of that?
I would like the crimper as well, sounds like that would be a lot easier than the single wire strip and crimp method.
trioval00 01-18-2006 08:09 PM
DITTO. send the web site info
rhklenke 01-18-2006 08:24 PM
Kevin,
I third that request, please post the details if you have them. I found the connectors at Newark (www.newark.com), but its a bit confusing to figure out what is needed to make a connection. Perhaps your source has it laid out better?
Bob
Topgun2mo 01-18-2006 08:34 PM
I had some custom harnesses made using those locking AMP connectors, and I have to say that they are very nice! I had the matching connectors put on my servos at the wings and now have a nice locking connector that easily unplugs.
eugen.iov 01-18-2006 09:13 PM
Hi Guys,
I spent some money on my own tools. I bought a MOLEX crimper capable of crimping Graupner wire. Costed me over $500 AUS + about $1.00 every pin. I have JR ends, male and female also FUTABA.
However I never use it soo far, stays there for a while now. To crimp one end costs $3.00 AUS if you make no mistake so both ends $6.00. You still need some wire in the plane but you have a lead to your spec. I am building now an Lightening (Composite ARF). I let you know how I am going. I crimped once with it and was PERFECT! but at what cost, don't ask me.
Regards,
EUGEN
KevinBarr 01-18-2006 09:13 PM
OK,
I will dig up the info and post it.
Hey Mike, I bet you thought I fell off the face of the earth :)
Hows the F-15?
1Eye 01-18-2006 11:03 PM
See post #17 [link=http://www.rcuniverse.com/forum/m_3627719/anchors_3629277/mpage_1/key_/anchor/tm.htm#3629277]here[/link] with links ...
the other Mike
Topgun2mo 01-19-2006 08:25 AM
Hey Kevin,
Yea, that's what I thought( I almost called Without A Trace).....as a matter of fact I have been waiting all this time for some landing gear springs...I'm sure there is some sort of explanation...........[X(]
However just last weekend I got in an order from McMaster Carr and I now have heavier main spring and also an inner spring in the main struts.:D
I intend on going to the Austin jet meet and Mississippi Afterburner this year. The 15 is ready to fly and will fly this spring!! I'm also working my next project.....a Reaction 54 morphed into an L-39
Take care
Flyjets 01-19-2006 08:33 AM
Kevin
I would really appreciate the info on this as well.
Currently I am working on a 13 foot Yak for IMAC flying that needs lead to the Tail that are over 9 feet.
Thanks for ur help
Ian
Topgun2mo 01-19-2006 09:32 AM
Ian there is an article on http://gsal.org/
Look under articles/electronics and the tests this guy did seem to suggest that twisted servo leads are the way to go for long runs.
volkan 01-19-2006 09:55 AM
i use something the same a kevin suggested, they are called ashloks, and are
basicly the same, but I sometimes use a 6 way, rather than a 2 way to
save me pluging in too many leads when its cold.
see http://www.rc-expertise.com/index.ph...ownload&id=174
http://www.rc-expertise.com/index.ph...ownload&id=175
http://www.ashlok.co.uk/
lov2flyrc 01-19-2006 10:08 AM
Dreamworks is now the US distributor for Ashlok connectors. First shipment due in this week. Have a look...
http://dreamworksrc.com/catalog/index.php?cPath=105_106
KevinBarr 01-19-2006 10:12 AM
Mr. Mikes post has the info I think your all looking for (Thanks Mike). I have never used the crimper he shows, only the one from AMP, but be warned that the AMP crimper may be $$$$$.
I am sure it will work to crimp individual pins/sockets.
Thanks.
rhklenke 01-19-2006 12:15 PM
Most excellent Todd. Just what we are looking for for our UAV stuff - will order soon!
Bob
CJ2002 02-04-2006 06:51 AM
ORIGINAL: lov2flyrc
Making up special to type leads is not a problem with the right tools, materials and proper procedures. I've just bought a replacement crimping tool from Ashtek here in the UK that crimps both the conductor and insulation in one go and makes a good, reliable connection every time...providing the basic rules are observed. As Todd sells Ashlok stuff in the States, I presume he'll be stocking the crimping tool...and maybe the good quality HD leads and connectors, etc, that's needed to do the job. Details of the crimping tool is available at:
http://ashtekelectronics.com/store/s...tool-p-82.html
They do a tutorial on lead making on their site and sell all sorts of other goodies too.
Cheers,
Dick
England
(Not a rep for anything...just passing information on)
Edited 'cos I can't spell!
mikuk 02-04-2006 04:17 PM
Hi,
Like Dick I have been doing my own servo ends for a long time without problems, I use either Als Hobbies or Ashlok for the best results, takes a little practise to get the technique right and I usually have a few scrapped. I have seen far more problems caused by people pulling on the leads to get the plugs out of the Rx than any failure on the part of the connector, anyone got a really good way to extract them, I normally a pair of curved forceps.....Mike
