Refuelling
How do you guys connect your refuelling line to your jet?
Any recommendations that allow for the least mess whilst connecting the supply line to the jet's fill line and be easy to connect/disconnect? Thanks all, ZM |
RE: Refuelling
I have an 8" floppy tygon from the UAT with a plug in it. So the acutally fueling connection is outside the airpane. Quick disconnects are easy, but can be a mess as you've found out!
RE: Refuelling
You could go [link=http://dreamworksrc.com/catalog/product_info.php?products_id=579]THIS[/link] route...
RE: Refuelling
1 Attachment(s)
Any questions?
RE: Refuelling
Thanks for the tips guys.
RE: Refuelling
I just put a Festo shut off valve on the fill line to the uat. It will reach outside the cockpit area.
RE: Refuelling
That seems like a good idea. Is it easy to disconnect tubing from festo valves? I always seem to have trouble and end up breaking the blue plastic lips.
RE: Refuelling
Todd's solution is probably the one that works with less mess. It is an excellent fueling system. NO LEAKS
RE: Refuelling
I had the same idea of putting a festo valve too, but why add more to the equation and yes Todd's nicer, that's all.
Festo fittings are black and so far I haven't had any problems with them. |
RE: Refuelling
I've used the slimline F1 system, and the Festo shut off valve...both work
| All times are GMT -8. The time now is 06:51 PM. |
