RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Harrier proto. (https://www.rcuniverse.com/forum/rc-jets-120/4019123-harrier-proto.html)
SJN 03-11-2006 04:18 AM
Harrier proto.
1 Attachment(s)
This looks neat.
"RC Pilot " from Taiwan posted these pics in our Danish forum.
EddieWeeks 03-11-2006 09:57 AM
RE: Harrier proto.
This is cool... Do you know how much work that is... Can you post the site with more info.. thanks
donniercjet 03-11-2006 10:13 AM
RE: Harrier proto.
thats sick!! if his prototype is sucessful its going to open a whole new level of flying!!
SJN 03-11-2006 10:46 AM
RE: Harrier proto.
There is no more info [:@]
I guess we will have to wait ;)
heres the link : http://www.rc-unionen.dk/nytforum/to...TOPIC_ID=12945
EddieWeeks 03-11-2006 10:55 AM
RE: Harrier proto.
Why are pic 3 and 4 different parts... ?
SJN 03-11-2006 10:58 AM
RE: Harrier proto.
you find him...and ask him :-)
I think it is the same part..... but pic 3 looks like the inner hot part, and pic 4 is the outer "dual wall"
Miniflyer 03-11-2006 04:42 PM
RE: Harrier proto.
Didn't someone ("pegasus"?) develop a turbofan for the harrier? He's been having some problems with it, i'm not sure about the status of his project.....but it was very very spectacular.
EddieWeeks 03-11-2006 04:45 PM
RE: Harrier proto.
Man.. I wish I could see a clear pics of the plane.. I am dieing to know how they keep it stable...
Eddie Weeks
GSR 03-11-2006 04:58 PM
RE: Harrier proto.
Doesnt look like the one that is flying is using the same thrust tubes as the parts he is holding. Also looks to be something on the ends of the booms-cant tell what it is-might be small props like the rig. It is not diverted thrust to the booms as I cant see any ducting. Need clearer pics.Scott
Woketman 03-11-2006 05:52 PM
RE: Harrier proto.
I think the dark line out to each wing tip is exactly that: duct work for reaction control jets.
Alex Chan 03-12-2006 01:40 AM
RE: Harrier proto.
This is a prototype of VTOL power by an Artes Rhino.
At the first 2 photo, the thrust provide by a turbine mounted vertically.
4 ducted fans mounted at the tips of the plane.
The stability is provided by 3 gyros.
The last 2 photo is the thrust transform system which will be mounted on the plane in the future.
Hope he will success.
CARBUNCLE 03-12-2006 01:30 PM
RE: Harrier proto.
Very nice work Alex. please keep us updated.
EddieWeeks 04-12-2006 10:03 AM
RE: Harrier proto.
I have been thinking about this... Those pic are cool, but anyone who can design and build that
thing must know how to work a video camera.
I have lots of video of my plane, but I only showed to the public the video of when it was
working. Interesting.
Best of luck.. and if you need any help let us know..
Eddie Weeks
http://www.corpcomp.com/weeks1/
SJN 06-13-2006 09:00 AM
RE: Harrier proto.
1 Attachment(s)
Updated pics posted:
Kevin East 06-13-2006 12:18 PM
RE: Harrier proto.
Saw the video on Skymasters site today. Look under the "new" section.
Kevin
erbroens 06-13-2006 12:20 PM
RE: Harrier proto.
1 Attachment(s)
that is a interesting solution for the pitch control on the harrier.. thx for posting it.
and this is not a Harrier, but a interesting hovering jet concept that I liked very much.
http://www.proxygen.com/36/Image.asp...59&sub_id=2131
Enrique
EddieWeeks 06-14-2006 12:09 AM
RE: Harrier proto.
How do they control the Yaw.. ?
Eddie Weeks
erbroens 06-14-2006 11:03 AM
RE: Harrier proto.
they just tilt the rear fans forward/backward each...one great thing about this design is that it already has thrust vectoring for fast forward speed, and coupled with those canards it could be conventionaly landed at very low speeds even if any of the engines fail.
Enrique
SJN 03-07-2007 03:34 PM
RE: Harrier proto.
1 Attachment(s)
MmmmmMMmm :D
FalconWings 03-07-2007 03:55 PM
RE: Harrier proto.
ORIGINAL: SJN
Very similar to the F-35 roll-post concept.
AirPac Models 03-07-2007 10:28 PM
RE: Harrier proto.
Li Kai is a modeler in Taiwan. He designed the mechanism and structure for this Harrier. It took him a few years from concept to the phototype skeleton test flight. It was quite a successful test in 2006 winter. Near one year after, he even improved some design of exhaust and balance and successfully flew the phototype skeleton version 2. He contacted Skymaster to make a shell for his Harrier.
The last picture you see was the phototype shell and fuselage that Skymaster did for him. This one will be unable to vertically take off. It is going to be set up as a normal plane. He will be using this to find out the correct CG and to also make sure that the wing folio is correct. If everything goes smoothly he will have a second phototype with his design that will be doing vertical take off. Best wishes for Li Kai.
flyreg 10-19-2007 10:46 AM
RE: Harrier proto.
found some nice video
http://video.google.com/videoplay?do...01086416552880
Wleppert 11-15-2007 05:32 AM
RE: Harrier proto.
Hello
From Germany
[link=http://www.mfm-muellheim.eu/mfm2/album_cat.php?cat_id=18]Harrier[/link]
Best wishes
Werner
Dave Wilshere 11-15-2007 06:46 AM
RE: Harrier proto.
Werner
That's big! The Eurofighter is a Eurosport from Comp ARF!!
Dave W
Wleppert 11-15-2007 08:40 AM
RE: Harrier proto.
Yes is a Composite Eurofither
The lang from Harrier is 2.9 meters
Wingspan is 1,84 meters
The Harrier is a full GFK Plane ( In Working)
Sorry for my English
Best Regard
Werner
