RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Epoxy Debonder (https://www.rcuniverse.com/forum/rc-jets-120/4090817-epoxy-debonder.html)
B1Driver 03-27-2006 08:00 PM
Epoxy Debonder
Hey guys, I got a latch that was epoxied onto the fuse of my aircraft and the latch has gone bad. What if any is the best way to liquify the epoxy so I can replace the latch? Its very difficult to reach with a knife and much more difficult with a dremel. Just wondering if theres a better way other than banging it out (sp) with a hammer [:@] THanks
Luis
Topgun2mo 03-27-2006 08:03 PM
RE: Epoxy Debonder
On;y 2 things I can think of.....grind it out or heat the latch with a soldering gun which could be dangerous
rcguy! 03-27-2006 08:03 PM
RE: Epoxy Debonder
Use heat...carefully!
Dave
seanreit 03-27-2006 09:51 PM
RE: Epoxy Debonder
Sandpaper?? And sore fingers
B1Driver 03-27-2006 10:13 PM
RE: Epoxy Debonder
I opted for the heat.. worked great! Pretty much melted the latch right off. On goes the new one, hopefully without putting epoxy on the spring like the manufacturer did. Thanks fellas!
Sean, it was the one for the cockpit hatch....I'd be sanding for a week.
Luis
GSR 03-27-2006 11:09 PM
RE: Epoxy Debonder
One sure fire way to debond any and all epoxy is to pull full up when inverted at about 75 feet up- That worked really well for me on Saturday. Scott
gboulton 03-28-2006 08:03 AM
RE: Epoxy Debonder
ORIGINAL: GSR
I THINK there's a difference between "debond" and "mangle", GSR.
:D
