Powerbox Evolution
I am building a boomerang XL and plan to use a powerbox evolution. I was wondering if duralite batteries can be used with this unit. If not, what kind of li-ion or li-po batteries are the jet guys using with non duralite powerboxes?
RE: Powerbox Evolution
Anurag
The std Evolution is designed to work with either 5 cell Nicad/Nimh or 2s Li-po batteries. Li-Ion is slightly lower in voltage. I either use Powerbox's 1500 Li-Po batteries with built in charger or 2s Thunderpower 2100 cells. Regards Dave |
Dave,
so does this mean I CANNOT use duralites? |
Anurag
You could use them, but you will get false readings on the battery monitor so should stop flying early. I'll ask Emmerich if anything is possible Dave |
Anurag
PB say its fine to use your Duralite batteries with the Evolution... Regards Dave |
Anurag, contact DuraLite for your Evolution Power Box and batteries. They have a complete set up wired especially for lithium-ion batteries and it comes with their fail-safe switch. It gives you redundant battery supply and divides the power comsumption for the servos and receiver. Very fool proof set-up and outstanding quality.
Regards, Richard |
Thank you Dave and Richard.
| All times are GMT -8. The time now is 11:15 AM. |
