Please help me identify this
I somehow misplaced at the field on a bad landing the brake hub to what I thought was a BVM Wheel. When I call BVM, they say their 3" wheel has a brake assmbly that fits over a 3/8" strut, not a 1/2" strut. To get a half inch strut, you have to go to the kingcat size wheel. But I looked at my kingcat, and it is too large a brake assembly. Can someone help me identify what I have so I can get another brake assembly?
http://www.my87.com/planes/rookie/100_0911.jpg http://www.my87.com/planes/rookie/100_0912.jpg http://www.my87.com/planes/rookie/100_0913.jpg http://www.my87.com/planes/rookie/100_0914.jpg http://www.my87.com/planes/rookie/100_0915.jpg |
RE: Please help me identify this
Sean
If I remember right, I used the same setup on my Roo. They are the BVM 3" wheels and brakes. The hub has to be modified to fit the Robart 1/2" strut. |
Look carefully at the first picture.
There is no modification on the existing one whatsoever. I already went back to the field to try to find the lost part, but no luck! Anyone? |
With further conversation with BVM, we found the problem!
Apparently for a short duration, BVM was making a special brake hub for Kanak, called the "Kangaroo Brake Hub"! They had not sold one in quite some time, and forgotten about them. Now I know the rest of the story, and you do too! |
1 Attachment(s)
Sean,
when I bought mine Kanak was out of them. I modified the stock BVM unit. |
Sean, I may still have one. I lost one, but kept the other. I will take a look this pm. Bob
Bob, if you do, I'll buy it from you as a spare.
Gary, did you dremel out the hub and not bench grind the strut? |
Sean,
I did not modify the strut. I used various dremel bits to modify the hub. Lots of trial fitting until the hubs seated all of the way. |
Gary, FYI you can bench grind the strut in about 5 minutes and make it fit.
Sean, the ones I have are 3/8 also. I found the struts and I did bench grind them. Bob
All this time BVM was making the miracle piece and now that we know about it, you can't get them anymore [&o]
It takes about 1 minute ,on a Bridgeport, to mill out the hub to .510. Thats how I modified mine. and you cant 't tell 'em from stock.
| All times are GMT -8. The time now is 08:53 PM. |
