CG for BVM Aggressor
Can anyone tell me the cg position for a BVM Aggressor.
MItchell |
RE: CG for BVM Aggressor
Which one?
I think this is the first Aggressor. How can i tell? It has one large hatch on top for access to the engine and the radio equipment is accesed through the nose wheel well.
MItchell |
1 Attachment(s)
Sounds like an Agressor II which I can help with. Is the TE of the wing basically straight and it has seperate flaps and ailerons?
It looks just like your picture. The wing trailing edge is almost straight and it does have seperate ailerons and flaps. Do you have a manual for it?
Mitchell |
Yup, lemme go look...
CG 2.75" behind the front edge of the bellypan - gear up and tanks empty!
Aileron 1/2" up, 5/16" down Elevator 1/2" up and down Flaps 30 degrees down |
Thanks for the help. If you can find the manual i'd sure like to have a copy.
Mitchell |
Are you building it? The CG and throws are not in the manual, they are on the plan. PM me you address and I"ll send you a copy of the manual...
This one is built. I am trying to rework it. I found out today that the new EVF is the same fan unit and was tested in the Aggressor and maverick DF kits. The Aggressor is a 140mph airplane with the electric setup and the fan is the Viofan.
Mitchell [email protected] |
| All times are GMT -8. The time now is 03:45 AM. |
