RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   f15 (https://www.rcuniverse.com/forum/rc-jets-120/4301480-f15.html)
wolfshound 05-21-2006 01:19 PM
f15
1 Attachment(s)
hello guys,i build the F15 from avonds ,df version,now i have modifications made for turbine,but on the stabs are 6mm carbonbares is this to light?
weasel33 05-21-2006 02:07 PM
RE: f15
1 Attachment(s)
Might be a good idea to get back to Philip
might have to modify the elevon system as well,mine are 8mm
This is parked outside the Armements Museum Eglin AirForce base Florida
Randy M. 05-21-2006 02:30 PM
RE: f15
A friend built one for turbine, he did upgrade the elevator shafts. May have been 8mm, I'm not sure. I'll get him to chime in later and let you know. I think he made some kind of jig as well to keep everthing in line. He replaced the sleeves as well. Good luck with it, it's a very nice flying plane.
Topgun2mo 05-21-2006 05:08 PM
RE: f15
I have the heavy duty turbine version and they are 8mm carbon shafts. I have smacked the stab on the pavement a couple of times and they suffered no damage.
renegade pilot 05-21-2006 05:18 PM
RE: f15
A friend upgraded his Avonds F15 to turbine and did not change the shafts from the 6mm originals.
The model was powered by a TJT2500 and unfortunately was lost after one taileron shaft broke. It could not be determined if there was any prior damage to the shaft i.e. any nicks in the carbon shaft before the crash.
For peace of mind I would change them out.
Russell.
Miniflyer 05-22-2006 02:17 AM
RE: f15
I am also rebuilding an Avonds Eagle for (twin) turbine. Threw out the 6mm ones, replaced with 8mm. I even considered going to 9 or 10mm...
From an engineering calculation point of view the 6mm will be plenty, but be sure never ever to nick, hit or dent the stabi hardpoint....else it is likely to fail.
So common sense sais: go safe, go 8mm.
Rgds
Hank
Henk Visser 05-22-2006 05:35 AM
RE: f15
I replaced mine for 6mm toolsteel. Works great and the original bearing can be used:D
wolfshound 05-22-2006 01:15 PM
RE: f15
1 Attachment(s)
thanks guys i wil replace it to 8mm .
i hope to maiden flight this weekend but the weater is not so good,rain en wind .
mayby toolsteel is also en offer.not so plenty work then.
vinnyjet 05-22-2006 01:38 PM
RE: f15
1 Attachment(s)
wolfshound
like your f-15
vinny
wolfshound 05-25-2006 01:39 PM
RE: f15
i have it replaced in 6mm toolsteel,saterday i go to due the maiden flight.
i will posted pictures.
greetings
Henk Visser 05-26-2006 02:00 AM
RE: f15
Wolfshound good luck!!!
looking forward for more picture's!;)
Gerald Rutten 05-26-2006 11:22 AM
RE: f15
1 Attachment(s)
Built mine in 1999 and has logged over 300 flights since with the old 6 mm shafts. A KJ66 with 85N thrust pushes it forward, would reconsider it though if I would upgrade it to 120N.
Good luck with you maiden....hope the weather will help a bit!!!!!
Best regards,
Gerald
