Kangroo control surface throws
my friend dave got a kangroo
need to know control surface throws he has the one piece elevons in it thanks vinny |
RE: Kangroo control surface throws
The manual calls for 25 mm for elevator and aileron functions. You need it on the elevator, but I recommend you double or triple rate the aileron for your first flights until you find out what is comfortable. I found 15 mm on the aileron was about right.
You will also need about 1/8 inch reflex on the elevons (up). Have fun....great jet. |
from the FibreClassics manual:
Elevator: +/- 25 mm > Aileron: +/- 20 mm >all with 20% expo Rudder: +/- 8-10 mm > CG 100mm in front of the leading edge of the main spar ************************* I use as high rate: Elevator: +/- 18 mm ( but I have working canards) Aileron: +/- 16 mm Rudder: +/- 10 mm all with 27% expo my low rate is about 75% of high and 23% expo |
hobby and crazy guys thanks
just want to make sure thanks again vinny |
Elevator: +/- 25 mm > Aileron: +/- 20 mm >all with 20% expo Rudder: +/- 8-10 mm > |
I used the max I could get on all the surfaces for the Roo-Roo and the Rookie.
ben and koenieboy
thanks alot i gave all the info to my friend dave he and i thank everyone you guys are great vinny |
| All times are GMT -8. The time now is 05:46 AM. |
