RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   PROTECH F15 (https://www.rcuniverse.com/forum/rc-jets-120/4477254-protech-f15.html)
debaker 07-08-2006 01:05 PM
PROTECH F15
1 Attachment(s)
if it interests anybody here are some pictures of a Protech F15 converted to turbine
it had its maiden flight this afternoon, then 4more[:)
weight 3lb 14oz dry
span 880mm
turbine Kolibri T-32
teg-1 07-08-2006 09:35 PM
RE: PROTECH F15
Very nice!
I have one of the planes myselve and was thinking the same thing,
Can you post some pics of the installation?
Thanks!
debaker 07-09-2006 01:53 AM
RE: PROTECH F15
Here are a few more pictures
i sat the turbine rails on the elevator plywood plates to give correct thrust line.
cut the front hatch out and fitted both battery packsto a ply plate on the nose
no lead was required as the balance was spot on
Dubro 12oz tank on cg
teg-1 07-09-2006 07:00 AM
RE: PROTECH F15
Can.t find the pics?
what thrust is your turbine rated at?
You can send some pics to my e-mail at
[email protected]
if it will be easier.
Thanks!
teg-1 07-09-2006 07:02 AM
RE: PROTECH F15
I did forget to ask what did you put the C/G at?
180 mm?
debaker 07-09-2006 09:50 AM
RE: PROTECH F15
1 Attachment(s)
CG is at 225mm as instruction sheet , i think the Kolibri is pushing about 3.5lbs thrust
siclick33 07-09-2006 12:05 PM
RE: PROTECH F15
Any more details of the engine?
How much did it cost? Where did you buy it from (any UK dealers)?
How does it run?
The F15 looks great and that little engine would be awesome for the club field.
debaker 07-10-2006 04:59 AM
RE: PROTECH F15
The engine is available from Martin Lambert in Germany www.lambert-modelturbine.de i dont think
he has a uk dealer.
the engine runs well and starts very quick with the supplied 12v air blower.
The cost, his larger turbines are cheaper but this little one is about £1700.
Crazy4Flight 07-12-2006 10:53 PM
RE: PROTECH F15
correction on the link...
http://www.lambert-modellturbinen.de/
