RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   REGAL EAGLE CG!! (https://www.rcuniverse.com/forum/rc-jets-120/4676735-regal-eagle-cg.html)
TorkRollN32 08-27-2006 04:31 PM
REGAL EAGLE CG!!
I need some help and fast please. could anyone tell me the Center of gravity on the Regal Eagle? I just need to know how many inches back it is. Plus if anyone has a manual that they would be able to email that would be greatly appreciated. thank you. Email is [email protected].
actionjackson 08-28-2006 09:05 AM
RE: REGAL EAGLE CG!!
Hi Torkrolln32,
I saw no one responded to your question so I thought I would try and help you out. I have a couple of unstarted Regal Eagles but it took a while to find the manual. Only one mention of balancing in step #78:
“ Balance your model by measuring from the trailing edge of the wing (not including ailerons) forward 11-1/2”. A slight nose down attitude is perfect, but remember if you are too nose heavy, then the jet will not take off”
I assume that TE start point would be closest to the fuse. I hope that helps. You might want to contact Bob himself with any questions at www.rcjets.com. I have found that he is great about answering them.
Good Luck
Steve
TorkRollN32 08-28-2006 04:30 PM
Thank you very much. Im glad to know that someone here still helps out a newbie to the jet scene. Thanks you very much
