RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Fail safe issue (https://www.rcuniverse.com/forum/rc-jets-120/4700530-fail-safe-issue.html)
funflyerf4 09-02-2006 08:41 AM
Fail safe issue
I have the Futaba 9c,how do you change the 20% that is preset by Futaba in the throttle fail safe mode?
Thanks Frank
whitcombe 09-02-2006 08:47 AM
RE: Fail safe issue
Frank, go into the failsafe menu and scroll down to the 20% throttle position. Then place the throttle stick in the desired failsafe position (idle) and press down and hold the joggle dial, the rotating thing. The tx will beep and the new value will be stored. So just position the throttle and press down and hold the dial until it beeps.
Tim Whitcombe
Edgar Perez 09-02-2006 09:38 AM
RE: Fail safe issue
or you can lower the stick and trim and set it up as 'shutdown'.. your call
AlW 09-02-2006 02:04 PM
RE: Fail safe issue
Frank,
Per current AMA rules the turbine must be shut off within (2 ) seconds of fail safe activation.
Al Watson
