RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   tip-tanks fabrication (https://www.rcuniverse.com/forum/rc-jets-120/5090561-tip-tanks-fabrication.html)
vasek 12-08-2006 11:47 AM
hi,
looking for an easy way to make tanks like the ones in this pic...
thanks,
V.
vasek 12-08-2006 11:50 AM
RE: tip-tanks fabrication
1 Attachment(s)
ok the pic didn't load, will try again
Wren Turbines USA 12-08-2006 01:15 PM
1 Attachment(s)
I have a damaged wing from a Lightning...you could use the tip for a mold....
Gordon Mc 12-08-2006 01:20 PM
Depends on the diameter etc that you need.
Given the time of year, you'll likely have a few carboard tubes lying around soon, from the inside of rolls of Xmas paper etc. If the diameter suits, take one of those, cut a few balsa circles that fit inside to give rigidity, slap on a light balsa or foam nose and tail section, then a couple of layers of lightweight glasscloth.
Gordon
Kevin_W 12-08-2006 01:48 PM
1 Attachment(s)
What are the dimensions?
I have a mold for the tip tanks and drop tanks on my Aeromacchi.
I don't remember the exact dimensions, but the tip tanks are about 3" diameter, and about 24" long, and the drop tanks are about 2" diameter and a little shorter.
mikuk 12-08-2006 05:14 PM
Use some plastic waste pipe of near diameter for the main body, put some balsa dowel on a drill/lathe WHY (make a mandrel if needed ) and turn to shape using a sanding block, glue into the waste pipe, seal the wood with thin cyano and use a little car body filler to blend in , ditto for the back end,finally, prime and paint. Drill to fit wing.........
dbarrym 12-08-2006 05:59 PM
Try using some model rocket body tubes and premade balsa or plastic nose cones and glass them, it will save a lot of work. If the diameter is larger than 1.5" or so, you could even get some phenolic or composite tubes for additional rigidity.
Some sources to check:
http://www.balsamachining.com/
http://www.semroc.com/Store/Products/NoseCones.asp
http://www.apogeerockets.com/building_supplies.asp
Good luck!
Barry
vasek 12-09-2006 02:03 AM
no1- thanks 4 the offer but i don't want make any molds (too much work);)
Kevin, 3" is too large i'm thinking 1.5 " or 2" max
I'll try the tube&cone deal most of you mentioned, since they don't have to be scale (just want to get some "scrape protection" for my BVM UViper wing-tips):D
thanks for the help
V.
