RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Reaction 54 control surface settings. (https://www.rcuniverse.com/forum/rc-jets-120/5122871-reaction-54-control-surface-settings.html)
phantom driver 12-16-2006 11:51 AM
Hello, I have a Reaction 54 that I purchased built, and I don't have the instructions giving the suggested control surface throws for it. What are you guys flying R-54's using for high/low rate settings on ailerons, elevator, rudder and flaps?Thank you.
swansons 12-16-2006 01:39 PM
RE: Reaction 54 control surface settings.
From Bruce's early IB the recommended control throws are as follows:
Ailerons 3/4" up, and 5/8" down
Elevator 5/8 UP and down
Rudder 1-1/2" left and right
Flaps full 60 degrees, down elevator mix with full flaps: 1/8"
He cautions that these are fairly active settings-so easy on the sticks for the first flight or two, then adjust throwns to suit your flying style.
I found these settings just about right for me.
John S.
dbarrym 12-16-2006 04:11 PM
I've found the book recommendations to be a good starting point, but I added 20% expo to the elevator and upped the aileron throws by 20%, and increased the aileron differential a bit as well.
Barry
phantom driver 12-16-2006 04:24 PM
Thanks guys.
