Tire making 101
1 Attachment(s)
I am in the process of building a Airworld ME-262 for twin P60 power. I am pretty happy with the kit so far, but I was a little disappointed that I couldn't find a set of tires that were even close to scale for this thing. A 4" tire looked a little small on it, a 4-1/2" tire is too large to fit in the wheel well, and nobody seems to make a 4-1/4" tire. Even if they did, I would seriously doubt I would ever be able to find one that was a wide as it needs to be to look scale (inch and a half).
So after reviewing this old thread from RCU: http://www.rcuniverse.com/forum/m_19...tm.htm#1909503 I decided to make my own tires and wheels. 1. I Started with a chunk of aluminum with a slightly larger diameter than the tire needs to be, and about half the width. 2. Turned it on a lathe until it is exactly like you want it (When you screw up fill the offending area with JB Weld and body filler then turn it to the correct size). 3. I didn't get any pictures of it, but I cut the treads by mounting the plug on a rotary table, then rigged a fence at the correct angle and cut a groove every 10 degrees with a hacksaw blade. Once one side was finished I reversed the angle on the fence and repeated the process. 4. Next I mounted the plug on a parting board (formica on plywood in this case) with a centering pin. 5. I added a suitable containment vessel (aka cool whip tub) around the perimeter. 6. Fill with molding RTV silicone and allow cure. 7. Next I mount the rubber mold half (with plug still installed) on another parting board with centering pin and two alignment pins in line with tread design. 8. Then I did a sloppy lay up of fiberglass around the entire thing. 9. Once cured, I removed the entire assembly from parting board, trimmed the excess fiberglass, and removed plug. 10. Repeat steps 4-9 for other half of tire mold. 11. I Filled both halves of mold with Urethane rubber and allowed to partially cure (after several attempts I decided that 1.5-2.0 hours worked best with the rubber I was using), then I joined the two halves with all three locating pins in place, and clamped edges with spring clamps. 12. After curing for 16 hours I separated the mold and had a new tire! |
RE: Tire making 101
1 Attachment(s)
For the rims I started with the Intairco brakes that I already had, and some 2 1/2 inch round aluminum stock. After using a sawzall, a lathe, and a milling machine w/a rotary table I ended up with what you see here. I still have a little more machining to do on the wheels (bushings and 10 screws to hold the two halves together and the tire in place) and I need to make the dummy brake hub for the inboard side, but so far I am pretty happy with what I've made. Not exact scale, but as close as I will ever get. |
RE: Tire making 101
Outstanding Effort!
RE: Tire making 101
Outstanding ability
RE: Tire making 101
VERY NICE !!!!
RE: Tire making 101
Outstanding!!! Whats next steel belted radials?? Awsome job!!
RE: Tire making 101
ORIGINAL: Pitts S1S Outstanding!!! Whats next steel belted radials?? Awsome job!! Thanks for the words of encouragement guys. I'll try to post more pics tomorrow or the next day when they are finsihed and mounted on the plane. |
RE: Tire making 101
I've been wanting to try this for some time, thanks for showing your excellent work!
Paul |
RE: Tire making 101
Watch out Glennis, there's a longhorn on the lose. NICE JOB.
RE: Tire making 101
Some folks just use whatever they can find that will work...and settle for it.
Some folks have the knowledge of the tools used...but don't use them. Some folks have the knowledge of the materials needed...but don't use it. But every once in a while, someone comes along who has the knowledge and the desire to make the best possible representation that he can. Thanks Kevin for being one of the latter and shring with us your excellent workmanship! Any plans for expanding your selection? Good FW and Me wheels are always needed!!! Happy New Year! Rob / katchmarek |
RE: Tire making 101
Nice work, Kevin. What is your US source (and cost) for the urethane rubber?
Mike |
RE: Tire making 101
Now that work is impressive. I especially am in awe of your ability to get the tread lines lined up so perfectly. Thanks for the details and the photos. Great work!
BC |
RE: Tire making 101
ORIGINAL: MrMike Nice work, Kevin. What is your US source (and cost) for the urethane rubber? Mike Kevin, great work and thanks for taking the time to share. I wish there were more of these type of threads here in the Jet forum. I'll just keep watching as every now & then a good one comes along....such as this one!!! Ronnie |
RE: Tire making 101
Very nice, Kevin! Anxious to see at at Waco.
RE: Tire making 101
Great job Kevin, keep us posted on your build too. Its one my fav jets.
V.. |
RE: Tire making 101
Great work - Very cool
All the best Greg Anixter |
RE: Tire making 101
You’re always my hero bud.
EXCELLENT WORK and keep us updated. Best Regards Ben |
RE: Tire making 101
phew! i feel much better knowing there was a sawzall involved in the mix!
RE: Tire making 101
Great work and talent.
Thanks for sharing. jef |
RE: Tire making 101
ORIGINAL: Countryboy ORIGINAL: MrMike Nice work, Kevin. What is your US source (and cost) for the urethane rubber? Mike Kevin, great work and thanks for taking the time to share. I wish there were more of these type of threads here in the Jet forum. I'll just keep watching as every now & then a good one comes along....such as this one!!! Ronnie Patrick, I would think that you know me well enough to realize that I can't build anything without the use of a sawzall! ;) Actually the sawzall was for cutting the rough block from the billet stock (since I don't have a metal cutting bandsaw), but I found that I could actually make some fairly accurate cuts with it. :D |
RE: Tire making 101
Hi Kevin
Your work on the tires & wheels are outstanding . How much fuel are you planning on carrying and where ? The Airworld kit is a great platform for a twin with the wing being one piece,keeping the fuel plumbing air tight , and IMO your choice of JetCat P 60s is ideal. I had one with the 7/8 pound manual start wren 44's but at 23 pounds with 86 ozs of fuel , needed to be flown at 100%. Semper Fi Joe PS if you need any special pictures of the 262 let me know as I have access to a 262b2(Two seater) Hi |
RE: Tire making 101
1 Attachment(s)
Well I didn't quite managed to finish the wheels this weekend, but I am close.
I got all the holes drilled and tapped for the tire screws (managed to hand tap twenty 2-56 holes without breaking the tool off :D ) I got the dummy inboard brake drums machined. These will do double duty as the wheel collar too. I also drilled some lightening holes in the inboard sides of the hubs, and machined a little "dead weight" off of the outboard halves. To complete the wheels hubs I just need to make and install the bushings. I have made a total of three tires so far. The first I tried to use backer rod (sold at Home Depot for backing up caulking) as a filler to keep the weight down. It was a disaster because after I joined the mold halves the ring of backer rod floated to the top of the mold and carried large air bubbles with it. The second time I decided to just make a solid tire. It came out looking ok, but it was extremely heavy. The third try I used some blue foam rings (one in each mold half) that I machined on the lathe as filler. I wasn't sure how big I could make the filler rings and still maintain a decent outer thickness of rubber, and as a result the foam rings ended up being relatively small and the tire only came out about an ounce and a half lighter than the solid one. I finally realized today that I can use the first tire (disaster) by sectioning it and using it as a guide for making the foam filler rings, so hopefully the next tire will be lighter. Pics of the progress on the rims: (with the full scale again for comparison) |
RE: Tire making 101
1 Attachment(s)
ORIGINAL: uncljoe Hi Kevin Your work on the tires & wheels are outstanding . How much fuel are you planning on carrying and where ? The Airworld kit is a great platform for a twin with the wing being one piece,keeping the fuel plumbing air tight , and IMO your choice of JetCat P 60s is ideal. I had one with the 7/8 pound manual start wren 44's but at 23 pounds with 86 ozs of fuel , needed to be flown at 100%. Semper Fi Joe PS if you need any special pictures of the 262 let me know as I have access to a 262b2(Two seater) Hi Four tanks, 40oz each. I will be using quick disconnect fuel fittings between the fuse and the wings. The two ECU's will mount in the center of the wing, fuel pumps will go in the front of the wheel wells, fuel and propane solenoids will be mounted in the engine nacelles, and the ECU batteries will be in the fuselage. At least that is the plan right now, things may change with balancing needs. I am hoping to minimize the number of connections I have to make for assembly at the field. Here are the kevlar tanks I made for it: |
RE: Tire making 101
Sweet Kevin............Spot on.:D
David Hudson |
RE: Tire making 101
Hi Kevin
Looks like your on the right track using the wing saddle and conformal tanks with 80 ozs /per of fuel those JetCats will be purring:D The airframe can take the added fuel weight,although I would hesitate on landing with anywhere near full tanks..looking forward to seeing the "Swallow"airborne. Semper Fi Joe |
RE: Tire making 101
Kevin, you are truly a genius!! Awesome work, dude.
RE: Tire making 101
Kevin,
Great job on those tanks, are you planning on using UAT`s?? The jet will fly fine nose heavy but will not tolerate any aft CG. Keep that in mind when you position those tanks. V.. |
RE: Tire making 101
ORIGINAL: Vincent Kevin, Great job on those tanks, are you planning on using UAT`s?? The jet will fly fine nose heavy but will not tolerate any aft CG. Keep that in mind when you position those tanks. V.. The tanks will go in the scale locations inside the fuselage just fore and aft of the cockpit. The front and rear tanks on each side will be Y'ed together so they drain equally. The CG will not change as fuel is burned off. I will not be using UAT's. I am planning to build conformal header tanks though and will use a pleated paper automotive fuel fitler clunk in each one of those. The header tanks will sit on either side of the cockpit, right on the CG. |
RE: Tire making 101
Hi Kevin, realy goodlooking tires you made there, compliments! Thought about this some times too but wasn't sure on the type of rubber to use. Do you have any idea on the wear when operating from tarmac?
I read about the trails on lowering the weight where you tried to put the foam halves inside. Maybe it's an idea to make an aluminium inside mould which you push in like the foam pieces but remove them once cured so you have a holow tyre, thickness to be experimented......? Best regards, Gerald |
RE: Tire making 101
ORIGINAL: Gerald Rutten Hi Kevin, realy goodlooking tires you made there, compliments! Thought about this some times too but wasn't sure on the type of rubber to use. Do you have any idea on the wear when operating from tarmac? I read about the trails on lowering the weight where you tried to put the foam halves inside. Maybe it's an idea to make an aluminium inside mould which you push in like the foam pieces but remove them once cured so you have a holow tyre, thickness to be experimented......? Best regards, Gerald For the latest tire I made some blues foam inserts that only allowed a wall thickness of about 3/16" all the way around and the good news is this tire seems to be about half the weight of the solid one. I will take them to the hobby shop later today to weigh them to confirm. I have no idea of how this material will wear under use, but you can be sure that I will be watching it closely for the first few flights. The main tires and wheels are finally finished and mounted on the struts. I am busy working on gear doors and the nosegear installation right now, but I will try to get some pics of them installed in the wing before the end of the weekend. |
RE: Tire making 101
Excellent work Kevin!
Something just occurred to me.............You might want to check the balance on the wheels once you get them molded and assembled. I remember when I had my hobby shop and RC car track, we used to balance the soft foam (very light-weight) tires and it made an amazing difference to the 1/10 scale cars. I don't think that it is much of an issue with our jets and the manufactured tires, but with your inserts you may get one out of balance quite a bit. That might make for some interesting high speed taxiing and takeoff! Tailwinds, John |
RE: Tire making 101
1 Attachment(s)
Hi Kevin,
Nice work! Hey do these pictures bring back any memories? BTW how did you intend on these covers to attach? Using the central hole in the mount I assume? For those of you that do not know, Kevin made some bypasses for awhile, I got a couple for an twin F-18 project (maybe 7 to 8 years ago?) and ended up using them on a MIG. They are the nicest ones I have ever seen, with clearances molded for the JetCat EGT and glow plug. Even has marks where to cut out the data cable and starter plug holes as well. Kevin is one of the best modelers I have ever known and I for one am glad he is posting here. I can only take so much of the soap opera after awhile! PS my sympathies to all Cowboys fans...... |
RE: Tire making 101
Yeah, I second what Matt said. I remember his sport jet from 6 years or so ago (can't remember what it was). He had increased the wing area and converted the horizontal to a full flying stab. Then added the external fuel tank that was droppable. REALLY cool (except if it hit pavenment)! He is a genuine craftsman.
Heck, what do ya say we elect Mr. Whitlow president in '08? |
RE: Tire making 101
ORIGINAL: Woketman Yeah, I second what Matt said. I remember his sport jet from 6 years or so ago (can't remember what it was). He had increased the wing area and converted the horizontal to a full flying stab. Then added the external fuel tank that was droppable. REALLY cool (except if it hit pavenment)! He is a genuine craftsman. Heck, what do ya say we elect Mr. Whitlow president in '08? |
RE: Tire making 101
RE: Tire making 101
Matt,
I can't take all the credit for those bypasses. I didn't make the molds. Actually, I did make the mold for the Jetcat cover, but Tom Robertson made the plug(s) and most of the molds. I actually still have those molds hanging on the wall in my shop waiting for Robertson to tell me he wants them back. :D Notice that the center hole in each mount ear is recessed for the washer and the outer two holes are not. You are supposed to mount the engine to the bypass with the two center screws, then the cover goes over these two screws (it is drilled to allow the screw heads to protrude through) then the outer four screws go in through the cover and the mount. That mounting system is definitely overkill, but it was a modification from the mount that Robertson designed for the original FD3-67, and 10 years ago when that was designed (wow, I'm gettin old) turbine knowledge/experience was non-existent for all of us. Woketman, I appreciate your kind words, except for that last sentence. President of what???? I doubt you would want me to be president anything, diplomacy is not one of my strong points. :D |
RE: Tire making 101
1 Attachment(s)
Now, pics of the 262 with feet.
I am using a robart nosewheel for setup, but I will most likely be making a scale nosewheel and tire later on. |
RE: Tire making 101
Hi Kevin
Looking at the photos ; are you planning on doing Flaps? or it just the way the light is hitting the wing Semper Fi Joe |
RE: Tire making 101
President of these United States!
But you're right. During the campaign someone would turn up with a video of you jumping, startled by those explosive P-80/Interceptor propane ignitions that we would see & hear during Mississippi Afterburner! :D That 262 is gorgeous. |
RE: Tire making 101
ORIGINAL: uncljoe Hi Kevin Looking at the photos ; are you planning on doing Flaps? or it just the way the light is hitting the wing Semper Fi Joe |
