RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   help with servo extentions!! (https://www.rcuniverse.com/forum/rc-jets-120/544878-help-servo-extentions.html)
Xwing 02-09-2003 08:41 PM
Does anyone know what the rule of thumb is on how long a servo extention can be without an amplifier? I have a byron f16 and the servos in the tail are going to be a long from the reciever up front.any tips before I wire??
jason 02-09-2003 10:04 PM
My f15 had over a metre long extentions for the tailerons and my starjet elevators and rudder has three extentions over a metre each all with no problems. Heavy gauge wire with gold connections are recomended by those who know there stuff.
jason
EddieWeeks 02-10-2003 04:51 PM
1 Attachment(s)
The plane below has no buffers / amps or anything
it has ~11 servos and some of the wires are over 6 foot.
I used 22 gauge 3 cond shielded and never had as much
as a bump with good power from the elev servos.
Its my option you don't need all the extra stuff.
Eddie Weeks
mr_matt 02-10-2003 05:46 PM
Hi Eddie
How did you ground the shield?
Pete S-RCU 02-10-2003 06:07 PM
Where can I buy connectors to make my own extensions?
I use JR equipment and would like to just use one extension no matter what the length.
Piecing together all these little extensions isn't a good idea.
JohnVH 02-10-2003 06:12 PM
Check your hobby store, 'custom electronics' makes ends for any radio type you need. And JR has wire itself in HD, 4' for $10. Diamond modelsport also has HD wire and its a lot cheaper, 10' for $4, just not JR colors.
Pete S-RCU 02-10-2003 09:04 PM
Anyone know what kind of connectors JR uses?
Are they like Berg-stik or Amp connectors?
There's lots of different ones, if I knew the name it would probably be easy to locate some locally.
KevinBarr 02-10-2003 11:50 PM
Connectors
1 Attachment(s)
You can also try a company called AMP. They make every connector you could think of. I use their MTE 3 line of connectors. They plug right in to a JR receiver and have a very positive lock. I make all my own servo extensions. These connectors have worked well for me for years.
The connector in the center of the picture, with the 3 wires is the type. work great!!!
My 2cents worth..
Kevin
Pete S-RCU 02-11-2003 01:09 PM
Thanks Kevin, how's the A-10 coming?
How's the F-86 coming?
What do you do in your spare time?
KevinBarr 02-11-2003 02:01 PM
Pete,
In my spare time I work. :)
How is your F-86 coming..Spring should be here in in a few more months..
Sick of the this 20 below stuff
Kevin
